I recently bought a needle point burner and neck tube for my Sievert torch. The neck tube has a brass 'plug' that fits into a conical shaped brass 'socket' in the handle. This is held in place by the captive nut which tightens onto the handle drawing the 'plug' into the 'socket'.
Although there seems to be no way of sealing this joint other than the pressure of brass on brass, the existing neck tube has been trouble free ever since I've had the torch.
Unfortunately the new burner doesn't seal, leaking profusely from the joint even though there is no discernable damage to the 'plug'.
The high cost of postage from Canada to the supplier in the UK and back again makes returning it for a replacement impractical, so any suggestions as to how I may cure this leak would be appreciated.
Thanks,
