Sieg X3 Tacho
Sieg X3 Tacho
  • #529357
    Clive Hartland
      @clivehartland94829
      I wish to fit a rev counter to my X3, has anyone done this?
      Source of parts and where to fit the counter.
      help please.
      Clive Hartland
        @clivehartland94829
        Fitting a rev counter
        #529372
        Bob n About
          @bobnabout
          #529374
            I bought a cheap tacho from e-bay along with a suitable transformer. Stuck the magnet to the spindle just below the gear with araldite and use one of the head top cover hole sto mount the sensor. Readout sits just under the e-stop button's panel.
            #529446
            Clive Hartland
              @clivehartland94829
              Thanks Jason and Bob, gives me a starting point. How this has come about is because I am slotting large bronze screwheads and the slotting saw is not happy. So I upped the rpm and it was fine. So I felt I need some reference of the rpm of the cutter.
              I will follow this up and see what I can do, Thank you.
              #529452
              not done it yet
                @notdoneityet
                Those chinese kits are simple cheap and easy to fit.
                An alternative solution, if only the slitting saw speed wax of interest, might be to buy a cheap hand-held taco as that could be used elsewhere.
                #529532
                Clive Hartland
                  @clivehartland94829
                  My X3 is cogged belt drive, not gears like Jasons. I can do nothing on top as the spindle can go downwards if I need Z drive facility.
                  I can perhaps place a sensor under the head and have a mark on a collar under the head, I wonder if it will get in the way there?
                  Perhaps i shall continue to fly by the seat of my pants regarding the cut.
                  Clivve
                  #529540
                    You could stick the magnet onto the top of the pulley and mount the sensor in a hole drilled into the top cover.
                    Or do as NDIY suggests just use a hand held one for the odd occasion you want to know the speed.
                    #529543
                    Ian Hewson
                      @ianhewson99641
                      on my sx2 I have a hole drilled in the drawbar cover for the sensor, and the neodium magnet just sticks to the drawbar, no glue.
                      Ian
                      #529563
                      Michael Cox 1
                        @michaelcox1
                        Clive, I do not know how similar your X3 is to my little X1 mill but I have added a tacho, see:
                        http://mikesworkshop.weebly.com/mill-tachometer.html
                        The tacho unit was supplied with a hall efect sensor but the sensor was too large to fit in a convenient place so a made a simple optical reflective sensor which works well using a reflective strip on the spindle.
