Sieg KX3 spindle motor replacement/upgrade
  • #782417
    Beardy Mike
      @beardymike
      My mill spindle has been cutting out at higher speeds for a while now, so I’ve been burying my head in the sand and using it at lower speeds until I got time to look at it. On Friday it started making awful noises and creating so much electrical noise it was interfering with the LCD monitor (I’ve never seen that before!).
      I’ve torn the head apart, and the coils inside the motor have a blackened section and smell of burning. Is this the sort of thing that I can get a new coils component for, or is it a whole new motor time?
      If I do need a new motor, that opens up the question of what to buy from where. The original part is labelled W92-1000K1, which I’ve briefly searched for a datasheet for to no avail. It’s very similar to the number W92-1000A that Arc sell for the SX3; would that be a drop-in replacement? Littlemachineshop seem to have the exact part – does anyone have any experience in dealing with them shipping to the UK?
      Another option I’d be interested in understanding is whether this is my opportunity to upgrade it. I know that the later KX3s had a 5,000rpm spindle – is that just an upgraded motor, or were there other changes? Anyone know what that motor is?
      Alternatively, do I even need to be buying this specific motor? How cross-compatable are servo motors – can I just buy one the right size/rating from elsewhere for less? I’ve got access to a mill at work if I need to cut a keyway etc. I can afford to spend £400 to get this machine back in action if I have to, but spending less wouldn’t be a bad thing!
      Thanks,
      John Haine
        @johnhaine32865
        You might look at the Jack industrial sewing machine motors that a number of people have used.
        https://www.tysew.co.uk/jack-jk-513a-550w-3-4hp-energy-saving-servo-motor
        Widely available and probably even cheaper on eBay or AliExpress.  Several people have posted about using them on here.  Getting Mach3 to control the speed might be tricky.
        #782427
        Robert Atkinson 2
          @robertatkinson2
          The sewing machine motor motor is NOT a direct replacement. It is also 550W compared to the originals 1000W.
          It is probably not economic to rewind the motor and may not be possible.
          The other concern is that the drive board may be damaged as well. Let’s hope not. The ARC Euro motor should fit OK. Generic motors are more of a risk. Even with the same physical size and voltage rating there are many variables for both the motor and encoder.
          Robert.
          #782437
            I’d be inclined to give ARC a call on Monday and see if the one they have will be OK in the KX3 and if not they may have something hanging around that is not listed on the website.
            #782509
            Matt Harrington
              @mattharrington87221
              I did some research on this with my similar Syil X4+ – it ended up with me changing the motor driver/inverter rather than the motor itself. I’ll see if I can fish the info out on a replacement motor for you – I’m fairly certain the Sieg & the Syil are v.similar. You may find a suitable BLDC motor from AliExpress….
              Matt
              #782545
              Huub
                @huub
                A new VFD for my Paulimot 1kW F207-V milling machine cost € 270,–. A cheap Chines AC servo set € 170. So I bought the Chinese AC servo set and the cheapest (€ 28) 1.5kW VFD on AliExpress. I mounted the VFD and it works OK for 2 month now. In 10 months I will replace the AC motor for the AC servo so I have electronic torque control for tapping threads.
                #782629
                Beardy Mike
                  @beardymike
                  I spoke to arc this morning – I’ve bit the bullet and shelled out the money to get a like-for-like which (as Jason suggested) they had on the shelf unlisted.
                  Thanks for the alternative suggestions, but having slept on it I realise that I’d rather get on with my actual project than starting a long-winded new one of converting the mill…
                  #782635
                  John Haine
                    @johnhaine32865
                    Probably a good decision Mike.  It would be useful to know why the motor failed though, did it overheat?
                    #782675
                    Beardy Mike
                      @beardymike
                      I suspect condensation. It started misbehaving no long after a big temperature/humidity swing that had my machines damp, and there was a few drops of what I think is water in the bottom electrical cover of the motor.
                      Overheating isn’t out of the question, but I’ve not taken any particularly heavy cuts lately and my workshop isn’t warm this time of year!
                      #782788
                      Metalhacker
                        @metalhacker
                        To avoid just such a potential condensation problem, I have mounted electric greenhouse heaters onto the stands of my lathe and mill, and never use any heaters which involve combustion and therefore water vapour. Uses about 300 watts for background heat for much well insulated garage workshop, and no rust or electrical glitches to be seen!
                        #784230
                        Beardy Mike
                          @beardymike
                          I’m back up and running! The arc motor matched on every specification I could see, apart from having higher temperature rating on the winding insulation – perhaps overheating was an issue with the earlier ones 🤷
                          I’ve just spent the evening cutting the original out of the wiring loom, and crimping on plugs so that I could then add matching plugs to the short wires on the new motor to connect it up. I couldn’t find the proper specs for the pre-terminated plugs (and neither could arc), but luckily my primary school education in matching up colours is still with me!
                          I’ve put everything back together and it now happily spins up to 3500rpm without complaint, horrible noises, or any other drama. It seems that the “buy once, cry once” approach has delivered.
