Sidevalve Single
Sidevalve Single
Home Forums I/C Engines Sidevalve Single
  • #173200
    Richard Evans 6
      @richardevans6
      Hi All
      First engine build here and I'm hoping for some advice from the experts.
      I have just finished an own designed sidevalve single around 11cc. So far it starts very easily and turns a 12.5×6 at 7000rpm but I'm struggling to get it running smoothly and it feels like its got a bit more to give. I suspect its a mixture issue. I have tried 2 completely different carbs without success but I don't have any idea what size bore I should use. I initially used a twin needle carb with a 7.5mm bore. If the throttle was opened all the way it would rev up and then die like its not drawing fuel, even with the needle valve completely open a pinch test showed it was lean. I then tried a single needle carb with a bore of 6.5mm and could not get to the same top rpm at any needle valve setting. I can lean it out with the needle till it gets peak rpm and if I go any further it dies yet when the tank runs out it smoothes out and runs best for a couple of seconds.
      I have also noticed a loss of power when the glow driver is removed at any rpm.
      My plan is to refine the design and build some multi cylinder engines. I might even sell some. I just need good reliable performance.
      the full spec of the motor is:
      Bore: 24.65mm
      Stroke: 24.00mm
      Compression: 9/1
      Valve lift: 1.9mm
      Ex open: 61 deg BBDC
      Ex close: 31 deg ATDC
      In open: 25 deg BTDC
      In close: 67 deg ABDC
      Glow plug: OS F-type
      Glow plug location: Bore centre
      The main variables that I think need looking at are the compression ratio, Glow plug location and carb type/diameter but I could be completely wrong.
      Any advice would be very welcome.
      Richard Evans 6
        @richardevans6
        #173209
          I'm no expert, but I understand four-strokes generally need hot plugs as they have to keep hot for twice as long between firing.
          Richard Evans 6
            @richardevans6
            Hi Neil
            Thanks for that.
            The OS F-type is a hot plug specially for four strokes. I have also tried hobbyking no3(hot) and enya no3(hot) plugs. The OS works the best so far but none are perfect.
            #173273
            Ady1
              @ady1
              You probably need a more specialised site than here
              Ron is dead now but there are are lot of engine heads out there who know tons of stuff and have their own sites/forums
              #173285
                Several of the "Motor Boys" post on MEM forum as well as quite a few others who build aero engines.
                Ady and anyone else interested another of the Motor Boys Adrian Duncan has now started a similar site to Ron's which can be found here
                J
                #173299
                Ady1
                  @ady1
                  Thanks Jason
                  #173400
                  Richard Evans 6
                    @richardevans6
                    Thanks for the info mate.
                  Home Forums I/C Engines Topics
