Showmans engine generator
Home Forums Work In Progress and completed items Showmans engine generator
Viewing 3 posts - 51 through 53 (of 53 total)
  • #264248
    Scrumpy
      @scrumpy
      Hi Len many thanks for all your time and help that you have put into this challenging subject but could you just clear a few points ( F1 -500 ma what voltage would I require ) ( R2 R3 is it 6RB or 6R8 ) also if I went down the line of Mike s suggestion how would I wire it up sorry for being so thick on this .
      I'm sure many people will have read the posts on generators producing light , I feel quite humble to think that so many people have helped on this project thank you ,and I'm sure many people in the next few years will read these posts with interest Derek
      John Rudd
        @johnrudd16576
        Derek,
        The resistor value is 6R8, or 6.8 ohms, or blue/grey/silver in colours on its body….
        The fuse just needs to be a standard 20mm glass fuse at the rating specified….( try your local Maplins)
        As for building the circuit or wiring it up, what did you have in mind?
        #269505
        Scrumpy
          @scrumpy
          Thanks everyone for your help a test set up has been made and it works
