Should there have been an oil seal?
Home Forums Beginners questions Should there have been an oil seal?
Viewing 2 posts - 26 through 27 (of 27 total)
  • #531842
    pgrbff
      @pgrbff
      Now I have looked at some of the other larger, thicker washers they are all similarly rough.
      The bearings were tight on the shafts, but the shafts look a bit battered, probably from previous bearing replacement.
      The bottom wheel is proving far more difficult. I have been tightening up the puller a bit and then applying heat to the hub but it won't come off.
      bottom wheel and puller
      not done it yet
        @notdoneityet
        I’ve no idea what loctite 648 is but there are so many different grades available. ‘Bearing-fit’ grade was often used by fitters at a place I worked, some 30 years ago.
