Next step: bearings are bought and received, via eBay; Koyo R16's from henderson c.£14 ea and KSM R12's from bearingsrus c.£9 ea, lower and upper countershaft respectively.
I plan to split the inner races of one each of the old bearings to make well-fitting spacers for refitting, probably using an angle grinder. I think that will make them easily removable after fitting?
My question for today is what or whether to grease the shafts and/or pillow block rebates before pressing the bearings into place – any advice please? I think doing so will prevent rust creeping in, as well as reducing friction while fitting, but I've no idea whether to use copper slip, LM grease, hypoid oil, 2-stroke oil, Castrol M (yep, a very old tin, mostly goes into model diesel fuel), 3-in-1, sewing machine oil is the lightest I know of, WD 40 (just kidding) or simply rely on the light grease that is already on the bearings?
Also, I will cleanup the shaft and rebate fitting areas but presume I shouldn't use a degreaser at risk of pulling any lubrication out of the surfaces?
Or should it all be completely oil free and de-contaminated, including bearings?
Too much imagination, not enough practical experience! ![laugh laugh](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Thanks, Nigel
