Thanks, everyone, fantastic advice. Apologies again I missed a couple of posts before my previous reply.
I don't remember it being particularly noisy when it was installed at the school, but there was plenty going on in the workshop. I think it was noisier than it should have been in my father's garage, which is why I wanted to try to isolate it from my garage floorslab from the outset. SWMBO sits watching telly just the other side of the wall dividing the spaces. No point creating problems if they're easy to avoid…
The garage floorslab is part of an attached extension, closer to the road. Late 1980's detached, normal footings, cavity wall, single glazing . I was under the impression that passing buses tend to shake the house, which I assumed came through the layer of roadstone which extends all around – the pile was temporarily here before the houses were built – but it might be airborne noise coming through the windows. I will focus on that (instead of trying to ignore it!), to see if I can tell which it is, but I hear your advice it's unlikely to be ground-borne, thanks.
My father re-wired the reversing switch and contactor (?) from 3-phase to single and fitted a suitable motor. I can't remember the power rating offhand but a torch and mirror should fix that. I remember him saying the contactor was tricky but I haven't found any circuit diagram he might have drawn, or maybe didn't reognise what it was for if I did see it, so he could have changed either or both item/s. Whatever, it's now stopped working! Hey ho, one thing at a time…
I wanted to address the feet first because once the lathe is back on the cabinet, I will struggle to raise the whole. I missed your second reference, Michael, I will read it thanks, but the nomograph in the first told me I would needed several inches of movement to be able to absorb 1500 rpm oscillations with high efficiency, if I understood it. I take your point that folk travelling this path end up with an air bed. I was still imagining modestly sized pads would help. I'm beginning to realise that's 'not so much'.
Yep, I said I plan to re-build progressively to try to identify any source/s, but I haven't been able to run the motor yet. The lists of potential problem areas are highly appreciated, thanks. Honestly, going from 'blindly trying it could be anything' to 'try a few of these' is a major step forwards. Also the advice that it's as likely to be panels shaking as rotating parts is useful – the base is a substantial thickness steel (.115" ) with welded dividers that produce 3 bays, all with a 2" lip at the bottom (four bolt-through pads beneath that), the top tray is almost .2" thick. Is that likely to oscillate? The doors seem to fit well but they are 1/16" and to be fair, tapping them produces noise similar to the general cacophany I remember, so I will focus some effort on those. Dedshete and isolate the door lip from the base if possible.
It does have one leather/rivetted chain belt and a v-belt that would have been installed back in the 1980's/90's when we got it, if not before. The chain came apart without too much of a struggle and I expected to reuse them but I will replace them instead in case, as suggested, they are transmitting vibrations onwards, thanks. Is there an improved alternative for the splittable belt? Sadly our local model engineering workshop in Derby, Des Gratton's, closed some years ago.
Think that's picked all your points. Softwood/hardwood point taken, Nick. Really thanks. I'd better go and do something! Apologies it has expanded from 'are rubber feet a good idea?' but it's covered my next few questions as well. Will report progress with photos.
regards
Nigel M
sorry, apparently double-quote close parentheses produces "
Edited By Nigel Monk on 04/10/2022 18:08:43
