Shortening HSS drills
Home Forums General Questions Shortening HSS drills
Viewing 25 posts - 1 through 25 (of 30 total)
  • #544942
    AdrianR
      @adrianr18614
      I have been wondering how much of a jobber drill is HSS. I am wondering if I could shorten some of my old drills to be like spotting drills or make countersinks.
      AdrianR
        @adrianr18614
        #544945
        Hopper
          @hopper
          Yes you can. The HSS usually goes all the way to the end of the flutes. Be aware though that the web in the middle of the flutes gets thicker towards the shank end of the drill so you may have to thin the web at the tip on the corner of the grinding wheel. Not needed on countersinks where there is already a hole in the job in that area of course.
          Edited By Hopper on 14/05/2021 10:28:19
          #544946
          Martin Connelly
            @martinconnelly55370
            If you want to shorten the fluted section then grind it back and re-sharpen it shorter.
            For the shank you only need to look at a drill that has slipped to see that the shank is soft. Try a hacksaw on one, if that doesn't work then grind a score around the shank, hold the part you want to keep in the vice and tap the piece you don't want and it should break off where the score is.
            Martin C
            Edited By Martin Connelly on 14/05/2021 10:30:59
            #544947
            mechman48
              @mechman48
              There shouldn't be a problem shortening drills;if they are carbon steel drills they would make nice stub drills which will have more rigidity, HSS will make decent spotting drills but you wouldn't need many, 2,3,,4 6 mm would suffice for most needs. One thing to ensure is that you maintain the correct tip angle 118* & equal length cutting lips otherwise you will drill oversize holes.
              George.
              #544962
              Mick B1
                @mickb1
                Generally the web will need thinning as Hopper says. The tendency to drill oversize may be reduced, as I think it's caused by uneven pressure on the longer of 2 unequal cutting lips flexing the drlll elastically, and the shorter drill will be stiffer – nevertheless still get the lips as even as possible.
                #545112
                bernard towers
                  @bernardtowers37738
                  Shortening jobber drills is ok for the odd job but they still flex as the shank is soft where the true stub drill is all hard
                  #545130
                  DC31k
                    @dc31k
                    Posted by bernard towers on 14/05/2021 23:36:20:
                    Shortening jobber drills is OK for the odd job but they still flex as the shank is soft where the true stub drill is all hard
                    Could you please provide an explanation of how stiffness (which is a function of Young's modulus and geometry) correlates to hardness. Thanks.
                    #545132
                      Posted by DC31k on 15/05/2021 08:25:23:
                      Not a direct answer, but : You may find this of interest: **LINK**
                      https://core.ac.uk/download/pdf/96764953.pdf
                      Keywords: Mechanical properties, High strength steel, Elevated temperatures, Post-fire residual strength
                      Edit: Young’s Modulus is only really valid for isotropic materials …
                      Edited By Michael Gilligan on 15/05/2021 08:50:19
                      #545134
                      Hopper
                        @hopper
                        Possibly because the soft shank is drill rod, aka silver steel, or the like whereas the hardened fluted part is HSS.
                        #545139
                        nigel jones 5
                          @nigeljones5
                          Lifted from the net – a bit vague but copvers the basics
                          The hardness (H) of a material tends to increase with an increase in the elastic modulus (E), yield strength (σy) and the strain-hardening exponent (n). Several materials with different combinations of elastic and plastic properties can exhibit identical true hardness (for a particular indenter geometry/apex angle). In general, combinations of materials that exhibit relatively low elastic modulus and high yield strength or strain-hardening exponents and those that exhibit relatively high elastic modulus and low yield strength or strain-hardening exponents exhibit similar hardness properties. Depending on the strain-hardening characteristics of the indented material, (i.e. n = 0 or ), the ratio H/σy ranges, respectively, from 2.2 to 2.6 or 2 to 20 (for indentations with a cone angle of 70.3&deg. The materials that have lower σy/E and higher n exhibit higher H/σy ratios. The commonly invoked relationship between hardness and the yield strength, i.e. H ≈ 3σy, is not generally valid or applicable for all power-law hardening materials. The indentation hardness of a power law hardening material can be taken as following the relationship H ≈ (2.1–2.8)σr where σr is the representative stress based on Tabor’s representative strain for a wide range of materials.
                          #545154
                          not done it yet
                            @notdoneityet
                            Seems like a overly complicated discussion.
                            Yes, drills can be shortened. Yes, they will be stiffer (less deflection) than a longer drill ( how many use extra long drills for ‘normal’ duty?). No, it won’t make a jot of difference re hole size for simple spotting use. Drilling is an axial cut, so deflection (stiffness) only becomes important if the drill is forced in and will likely then a) cut an oversized bell-mouthed hole and b) not drill straight. Very small diameter drills are more susceptible to bending.
                            Yes, you can shorten them and use as countersinks, but why do you think countersinks are manufactured and sold as a distinct product? There are good reasons why drills are not always good for countersinking.
                            Short or shortened jobber drills are just that – short jobber drills.
                            I have quite a lot, collected because my mill is head-space restricted. It’s why I have them and how I use them – for drilling holes.
                            Spotting drills are specially produced for spotting – stiff and drills at the point. A specialist item retained for a specific use. Most ordinary twist drills require a spot to locate it (to prevent skidding on the surface).
                            Short cuts are not always the best way to go – unless just to get the odd job done quickly or without the best tools.
                            #545156
                            ega
                              @ega
                              Posted by Hopper on 15/05/2021 08:48:58:…
                              I admit to being surprised by this – how would the manufacturer vary the composition of the steel as between the soft shank and the hard flutes?
                              #545158
                              duncan webster 1
                                @duncanwebster1
                                DC31k has it right, the Young's modulus of HSS (M2 grade) is 200 GN/m^2 HSS whereas carbon steel is 207 GN/m^2 (Data and Formulae for Students, Anderson, Hum, Neal, Whitelaw). It is a common misconception that increase strength or hardness necessarily give increased stiffness. If you harden silver steel it also gets stronger, but its Young's Modulus doesn't change at all as that is largely down to chemistry
                                #545163
                                AdrianR
                                  @adrianr18614
                                  Hijacking my own thread, the last time I dealt with Young's modulus etc was 1982 at uni.
                                  I am thinking of making a QCTP and holders. I understand hardening would reduce the wear and I could live with a little wear, but would unhardened be strong/rigid enough?
                                  #545171
                                  Tony Pratt 1
                                    @tonypratt1
                                    Posted by AdrianR on 15/05/2021 10:23:11:
                                    Unhardened steel will be plenty good enough for your home workshop tool post, I thought we had established that 'hardened' steel is no more rigid than 'unhardened' steel?wink
                                    Tony
                                    #545186
                                    Howard Lewis
                                      @howardlewis46836
                                      My rear toolpost was made from a length of ground steel of unknown provenance, but was not particularly difficult to machine, so probably Mild Steel. (It consists of a number of laminations, each machined differently from the others )
                                      It has survived well over a decade without showing any obvious signs of wear.
                                      A toolpost is not normally subjected to high rubbing speeds whilst loaded. If heavily loaded whilst static, wear is unlikely, although there may be some deformation if the loads were great enough.
                                      If the loads imposed on a toolpost were so great as to produce permanent deformation, the rest of the machine would suffer also.
                                      Given the likely load carrying areas in a toolpost, you can probably survive without resorting to anything too exotic in material or heat treatment, especially in a hobby, rather than an industrial, environment.
                                      #545198
                                      Mick B1
                                        @mickb1
                                        Posted by ega on 15/05/2021 09:59:44:
                                        Well, they might induction-weld the HSS active portion onto a CS shank prior to finishing flutes, point, shank and cylindrical lands.
                                        I don't know, but my guess is this would be more expensive than making the whole thing out of a single HSS rod, finish machining and then heat-treating to harden only the fluted part – so I think that's what they'd do..
                                        #545201
                                          Tend to be from HSS Rod for the full length, hardened (not the shank) quite early on in the process then ground, larger diameters may be part formed before hardening and finishing.
                                          #545293
                                          duncan webster 1
                                            @duncanwebster1
                                            Drifting a little off topic, railway waggon buffer heads were flash butt welded to their shanks. Bring them into contact, pass a large current to get them very hot and then squeeze. You might use f
                                            Riction welding nowadays.
                                            #545307
                                              If you want to make stub drills, you could do worse than make straight flute drills from silver steel.
                                              They have several advantages, but don't drill deep holes.
                                              Another easy style to grind is a triangular cross-section drill with a pyramidal tip, and a notch in each edge of the tip. Is supposed to work well on hard materials.
                                              AdrianR
                                                @adrianr18614
                                                The reason I was looking at modifying them is that I have inherited both my fathers and stepfathers drills. I have defiantly also inherited the packrat gene and can't bear to throw them away. A lot have worn sides near the tips, but nearer the shank they are fine. I don't have stub or spotting drills so thought it could be a good way to be trendy and upcycle them.
                                                I always thought drills were made in two parts and welded together. It seems that would be easier than trying to do HSS heat treatment at one end of a drill.
                                                #545346
                                                Tony Pratt 1
                                                  @tonypratt1
                                                  Posted by AdrianR on 16/05/2021 08:38:40:
                                                  Smaller HSS drills are definitely solid HSS, it's an easy job to harden say 2/3 of the length using an induction hardening process, as for the larger drills I'm pretty sure they would be solid HSS, introducing welding into the manufacture would be a nightmare but may have been attempted? There are interesting videos out there showing twist drill manufacture.
                                                  Tony
                                                  #545364
                                                  Hopper
                                                    @hopper
                                                    They used to be made that way. Or so we were taught at tech college in the 1970s. I never actually worked in a drill factory! Was told it was mostly a cost saving measure as HSS was once upon a time exotic and expensive. Supposedly also allowed a little more flexibility and bend where the hardened HSS would crack and also allowed the chuck to grip the softer shank. I vaguely recall we were told the two parts of the shanks were friction welded together by rotation of one against the other stationary one. (You can do this with steel bar in the lathe at 800rpm if you like experiments.) Possibly also induction welding etc in later years. You could actually see the join and the two different coloured steels on some old drill bits.
                                                    It seems these days most smaller size drills are full HSS as the price of the material has come down. I would think some larger drills, especially those with large Morse tapered shanks larger than the fluted section of the drill are still probably made from two pieces welded together.
                                                    So if your Dad's bits are old, they may well be made in the old two-piece blank way. Worth keeping them as most of those old drill bits were pretty good, much more so than the cheap hardware store offerings these days.
                                                    Edited By Hopper on 16/05/2021 10:06:37
                                                    #545365
                                                    AdrianR
                                                      @adrianr18614
                                                      Well I never, learn something new every day, just watched this,https://www.youtube.com/watch?v=u6ADHf3nvIs shows them treated in salt baths.
                                                      Looks a lot simpler than what I read for the HSS hardening and tempering process.
