Posted by Chris George on 14/05/2020 06:53:11:
Im new to machining parts and was wandering about the correct Dia to machine a shaft to?
I have a shaft that has a bush (20mm ID) pressed onto the end giving it a snug fit. What size do I machine the shaft to to ensure the snug fit but not to split the bush when pressing it into position?
Regards Chris
Is this professional or amateur work?
The tolerance tables on the web are for making interchangeable parts as needed in manufacturing. They're complicated! Originally done by having a tool-maker make accurate GO/NO-GO gauges, jigs, fixtures and other gizmos so the shop-floor can get it right repeatedly. Now CNC and other fancy machines and methods, mostly beyond small workshops.
So for most amateur work, we go for the older technique, which is fitting. Rather than make stuff precisely to a specification, instead parts are made close to size and then machined fit together. In effect one part is the gauge. With a shaft and bush, its usually easier to machine the shaft to fit the bush. The disadvantage of fitting is the parts aren't fully interchangeable, which makes mass production expensive because everything needs to be fitted during assembly and again during maintenance. But the method is great for small scale operations, ad-hoc repairs, and any circumstance that doesn't demand interchangeable parts.
Older books are often more relevant in home workshops than modern tables. Tubal Cain's Model Engineer's Handbook (recommended) has a simplified table for Shrink, Force, Drive, Wheel-Keying, Push and Slide fits. For a drive fit, TC suggests adding 0.45 thou per inch of diameter plus 0.3 thou.
Don't trust my maths but for a drive fit into a 20mm hole, I make the shaft 20.01662mm
As that's difficult to measure accurately, (an ordinary micrometer has 0.01mm or 0.001" graduations), I'd lock the micrometer between the 20.01 and 20.02 mm lines and use it as a 'close enough' GO gauge. This approach assumes the bush has an accurate 20mm hole, which it probably does. Another way to do it is to turn a bit of spare rod so it just slides into the bush, then set a divider on it plus the thickness of a thin Rizla cigarette paper (about 0.02mm). The shaft is turned down until the divider just slides over it – the result should be 'close enough'.
