I was recently given a defunct sewing machine to dispose of in case I wanted the motor. This motor was in good nick and really quiet, so that came off. I then had a look inside to see what was there. Lots of weirdly shaped rods and levers that could only one use; their original one! However, I found that it also contained a pair of helical gears with a 2:1 ratio; one steel, with a bore of 1/2", the other is brass with a steel cam press into it. The cam has a 1/4" bore and could probably be removed leaving a 7/16" bore. The shaft centres are 3/4" apart. It made me wonder if there are any I/C engine drawings that these gears would suit? Or are they a bit on the small side?
Maurice
Edited By Neil Wyatt on 28/03/2018 22:09:00
