The standard method is to put your round bar in an accurate 3 jaw chuck (if not accurate, then use an independent 4 jaw) Adjust until the free end is running true and then very carefully adjust supports on the fixed steady and job done.
This is fine for an 8" length of 3/4" diameter bar. However I am trying to set up a 10" long bar of 3" diameter material.. Trying to adjust this on an ML10 is far more daunting! In fact I gave up trying after a fruitless 20m minutes. Having such a large unsupported lump, also struck me as a possible accident in the making.
Ideally if one can centre both ends with a centre drill, you can support the rod between centres. Then the setting up of the fixed steady is easy. I can accurately mark the centres and even centre punch them! But how to centre drill both ends? My mill is in pieces at the moment, so I just have the ML10 and a rough old Chinese drill press.
I am sure I am missing something obvious, so how would you set up the fixed steady for this job.
Thanks,
Andrew.
Edited By Andrew Tinsley on 27/06/2023 19:11:45
