Setting bearing preload.
Home Forums Workshop Techniques Setting bearing preload.
Viewing 2 posts - 26 through 27 (of 27 total)
  • #181527
      A slight digression [given that the question raised by Chris seems happily resolved]
      It is perfectly possible to build a useful spindle using one Taper Roller Bearing, and 'whatever' at the other end. … The TRB then acts in way similar to the bronze bearing at the front of the Myford S7 [or the Mega Adept] Headstock, but without the need to pre-set a critical 'oil-film' clearance.
      … This may have some merit for heavy duty drilling spindles.
      Capstan Speaking
        @capstanspeaking95294
        I used to be a Toolmaker at British Timken (RIP).
        Counting turns will vary with the thread pitch. The proper procedure is to measure the static torque via a spring balance on an arm.
        The shortcut is to nip it until there is the faintest drag when turning by hand. Lock it there or if you have a castle nut then back off to the first split pin slot.
        More sophisticated set-ups may have spring shims.
