Serious Readers, serious prices
Home Forums The Tea Room Serious Readers, serious prices
Viewing 25 posts - 1 through 25 (of 55 total)
  • #464573
    ega
      @ega
      My Serious Readers brand LED desk lamp wouldn't turn on this morning and, having checked with an alternative mains socket, I looked on the SR website for a replacement bulb.
      The lamp has been in continual use for some years and the cost of £44 including postage may well be justified; it would, however, buy a (non-SR) replacement lamp!
      My knowledge of LED lighting is limited but I suspect the bulbs are SR-specific. It would be good to know if there is likely to be a generic replacement available or, indeed, any other useful comment from members.
      ega
        @ega
        Can I justify the cost of a replacement bulb
        #464576
        Kiwi Bloke
          @kiwibloke62605
          LED technology has come on a bit in the time you've apparently had your lamp. There seems continually to be more choice, prices have come down a lot, and availability to the public is much better. I think I'd be looking to re-engineer the lamp to take something easily available.
          #464578
          Former Member
            @formermember19781
            #464579
            Former Member
              @formermember19781
              #464581
              Ian Parkin
                @ianparkin39383
                Ega
                Are you sure its the “bulb”
                i would suspect the power supply first
                and certainly SR wont be making leds so its just a matter of finding the emitter part of the bulb
                #464616
                ega
                  @ega
                  Gentlemen:
                  Many thanks for your responses. I will check the power supply and think about the re-engineering suggestion.
                  In the meantime I have replaced the lamp with a budget item from Ikea whose cost was about one fifth of the cost of the replacement bulb.
                  #464631
                  Ian Parkin
                    @ianparkin39383
                    What’s the bulb look like ega?
                    can you post a picture?
                    can you see the difference between bulbus expensivicus and the ikea one?
                    #464641
                    Howard Lewis
                      @howardlewis46836
                      It is known as "Market Place Pricing" or "what the traffic will bear"
                      If nobody buys, the price will fall!
                      It may well be worth re engineering the standard, if it needs it, to a standard lampholder, and then fit one of the more economically priced LED lamps, either BC, or E27
                      #464642
                      ega
                        @ega
                        Ian Parkin:
                        I've put photos of the bulb and PSU in an appropriately named album. The SR bulb is 50mm dia, the Ikea item (which is stated to be non-replaceable) c. 28mm dia.
                        Thanks for your continued interest. Might you elaborate your "emitter" point (I think of valves when that word comes up)?
                        #464645
                        ega
                          @ega
                          Posted by Howard Lewis on 14/04/2020 17:08:59:
                          Two standards for the price of one?!
                          SR do make some "serious" claims about the quality of the light from their lamps. A relative whose judgment I trusted had a couple of these for many years and I probably bought on the strength of this.
                          I suppose the other consequence of nobody buying would be the seller ceasing to trade.
                          Thanks for the pointer to LED bulb types.
                          #464650
                          Andrew Tinsley
                            @andrewtinsley63637
                            Unfortunately, outfits like "Serious Reader" are little more than a con. In the days of Halogen lamps, they just used ones from the major manufacturers. Nothing special at all! Exactly the same with the newer LED versions. They charge an arm and a leg for bog standard lighting products.. You can get better engineered luminaires from most of the lighting retailers. for a fraction of the cost.
                            It has been my misfortune to have to repair a couple of these offerings and they are simply crap. In case anyone questions my opinions, I have been involve in lighting R&D for well over 20 years, so I know what I am talking about!
                            Andrew.
                            #464654
                            Howard Lewis
                              @howardlewis46836
                              ega,
                              By standard, I meant modifying the whole device to use a standard lamp holder (Bayonet Cap or Edison Screw ) In that way replacement lamps will be widely available, at sensible prices, and easily obtainable.
                              Petrol or Diesel may be £7 a litre at the pump, but can be much more expensive when someone brings it to you after you run out five miles from home at midnight!
                              If I make something which is held together with 7 mm x 10 tpi bolts, I will capture the spares market and can charge silly prices, until someone starts making spurioius spares, or a conversion kit to allow use easily available fasteners.
                              #464665
                              Ian Parkin
                                @ianparkin39383
                                Ega
                                so have you fitted a 12v bulb?
                                and used your original power supply?
                                if all that works and the lamp is held securely and you like the light output then everything’s ok?
                                #464666
                                Enough!
                                  @enough
                                  Posted by Howard Lewis on 14/04/2020 17:39:54:
                                  Really? Gotta be something wrong … a typo? It's 65 cents (CDN) a litre here.
                                  #464678
                                  Former Member
                                    @formermember19781
                                    #464683
                                    Howard Lewis
                                      @howardlewis46836
                                      Bandersnatch,
                                      Where you live, you are not paying more tax than for the fuel,
                                      Bill Chugg,
                                      They omitted to say "And profitability"
                                      #464685
                                      Mick B1
                                        @mickb1
                                        I came across an advert for Serious Reader lamps IIRC in the back of the TV comic we buy.
                                        I'm afraid I was instantly suspicious – I wondered what they do that a <=20 squid anglepoise clone from Ikea or suchlike doesn't. I've never found these latter deficient – we've several in various places in the house, including one mounted over the Warco. What's supposed to be unique about the SR light quality?
                                        #464686
                                        Andrew Tinsley
                                          @andrewtinsley63637
                                          What absolute BULLSHIT, "superior light quality"……….."They are unique and deliver the core benefit of the light".
                                          These people should be prosecuted for such rubbish. They are run of the mill, mainstream manufacturer's lamps in shoddy luminaires., at seriously ridiculous prices.
                                          Andrew.
                                          #464692
                                          Peter H
                                            @peterh38181
                                            They look like standard MR16 12v LEDs to me.
                                            #464693
                                            Mick B1
                                              @mickb1
                                              Posted by Andrew Tinsley on 14/04/2020 19:42:34:
                                              Andrew.
                                              You'd end up jamming the courts with them and their like, then. laugh
                                              I spent long enough in the software industry to recognise undefined 'quality' hype – but then it's everywhere, in every business area.
                                              Edited By Mick B1 on 14/04/2020 20:09:28
                                              #464699
                                              ega
                                                @ega
                                                Thanks to everyone for throwing some "superior light" on this.
                                                The suspect bulb is indeed a 12v 5w MR16 – not something I have in stock but no doubt I can get one when the Corona dust settles.
                                                I will aim to check the power supply first, however, and the Ikea will serve for the time being. I think I caused some confusion above: the Ikea replacement is a whole lamp ie base, gooseneck and integral bulb.
                                                Howard Lewis:
                                                I took your first standard to be standard as in standard lamp – sorry for any confusion!
                                                As it happens, I have a vintage Anglepoise which could find a permanent home on my desk and, with some modification the SR could make a useful machine lamp.
                                                Edited By ega on 14/04/2020 21:05:25
                                                #464700
                                                Robert Atkinson 2
                                                  @robertatkinson2
                                                  Google GU5.3/MR16 5W LED pick a beam angle and "colour"
                                                  e.g. https://www.ledbulbs.co.uk/products/philips-5w-led-gu53-mr16-very-warm-white-71063 (I don't know this supplier, do your due dligence)
                                                  At a few quid it's worth a punt. pretty sure it will fit and OK electrically.
                                                  Robert G8RPI.
                                                  Edit MUST TYPE FASTER!
                                                  Edited By Robert Atkinson 2 on 14/04/2020 21:08:03
                                                  #464705
                                                  ega
                                                    @ega
                                                    Posted by Robert Atkinson 2 on 14/04/2020 21:06:58:
                                                    Robert G8RPI.
                                                    Thanks for the tip. This does seem to be a commodity market which was probably not the case when I bought my SR unit in c 2013.
                                                    #464713
                                                    Stuart Smith 5
                                                      @stuartsmith5
                                                      I have found the craft light company to be good.
                                                      Serious Readers are very expensive as others have said. I must admit, I don’t understand why people buy them.
