BZP screws when hardened have a strength of 1200 N/mm^2 minimum. Stainless, if A2 or A4 type has a strength of 800N/mm^2 at best, and possibly down to the 450 N/mm^2 mark depending on the amount of work hardening and temp at which it was work hardened (some are done at high temp to soften the steel, which reduces the amount of work hardening possible). Thus they are considerably weaker and more likely to strip the thread.
The other problem is the wretched material has a habit of micro welding (galling) under pressure which produces a very effective weld just where & when you don't want it. Having welded itself to the substrate, something else breaks. And frequently, under sod's law, so does the strong weld that caused the 'something else' to break.
So, yes I have experienced it & always try to use BZP. Then slather with paint/goo to stop rusting if outside.
Richard.
