Selecting a size of boiler to a marine steam engine of known size..
Home Forums Model Boats Selecting a size of boiler to a marine steam engine of known size..
  • #46629
    Jens Eirik Skogstad 1
      @jenseirikskogstad1
      Hi all folks!
      I has a twin cylinder double acting steam engine, the bore are 1/2″ and stroke 5/8″ (12.7 mm x 14.7 mm). Working pressure are 29-44 PSI (2-3 Bar).
      How can i find the right size of boiler from smallest to biggest in this range adapted for a steam engine where the cylinder volume are known?
      Are there some calculation to find the size of steam boiler when the cylinder volume are known?
      Merry Christmas and Happy new year to all folks in forum!
        @jenseirikskogstad1
        #46631
        Circlip
          @circlip
          And a very Merry Christmas to you too Jens Eirik. It’s a bit late for a Christmas present, but a book which falls into your requirement is “Model Boilers and Boilermaking” by K.N.Harris. Not only does it give a full explanation of how to size a boiler but shows the construction of various types.
             Best  Regards  Ian.
          #46639
            @jenseirikskogstad1
            Thanks, i am trying to seek after the book “Model Boilers and Boilermaking” and buy/bid if the book are in Ebay.
            #46652
            AndyB
              @andyb47186
              Season’s Greetings to everyone.
              Jens,
              Try Amazon, the UK site has several for sale
              #46655
              Circlip
                @circlip
                Jens, you should be paying NO MORE than £14.99 for a NEW copy of the book.
                       http://www.teepublishing.co.uk/search.php   and http://www.camdenmin.co.uk/have them. Had there been any current Model engineering Exhibitions, you could have probably bought it cheaper.
                   Regards  Ian.
                Edited By Circlip on 26/12/2009 13:04:24
                Edited By Circlip on 26/12/2009 13:08:45
                Edited By Circlip on 26/12/2009 13:10:57
                Edited By Circlip on 26/12/2009 13:12:23
                #46667
                  @jenseirikskogstad1
                  A lot of thanks! There are really cheap books
                  I has a question about the boiler:
                  The time steam boiler will give steam quantity in a time period determined by the amount of water?
                  Vapor pressure is determined by the heating effect provided by the burner or the size of heating surface?
                  Are this correct?
                  #46678
                  Circlip
                    @circlip
                    Jens, your command of English is far better than my command of your native language, but to answer what I think you have asked :-
                      A given content of water in any boiler is capable of generating a certain volume of steam. The way to increase the volume of steam is to feed the boiler while it is operating, with more water to compensate for that which is evaporated. You do this by adding a boiler feed pump which can be operated manually or coupled to the engine but needs to be controlled within limits so that not too much OR too little is fed in.
                      Vapour (Steam) pressure is controlled by burner heat and also heating surface which are determined by  the evaporative rate of a boiler, but the design of the boiler controls the efficiency of the heating surface.
                      DON’T stop asking questions, but it will become a lot clearer when you see the book mentioned. K.N. gives worked examples of how to “Size” a boiler for the engines requirements and also the different DESIGNS of boiler for different applications.
                       There are times when you want to tear your hair out with the course you have chosen to amuse yourself with, but it IS worth it in the end.
                       Regards  Ian.
                    Edited By Circlip on 27/12/2009 10:52:00
                    #46719
                    Alan Worland 1
                      @alanworland1
                      I have just purchesd the above mentioned book from Ebay (10.50 inc p&p) in the hope it will help establishing my boiler feed water supply – there were 2 on there, the other one went for £7 or so!
                      I dont know when the book was first published but I am also hoping that I might be able to identify my existing boiler design.
                      #46742
                      Circlip
                        @circlip
                        I’d be surprised if you couldn’t Alan, only about thirteen different designs in it.
                           Regards  Ian.
                          An if the guy I LENT my copy to is reading this, can he let me have it back, with the other three he BORROWED.
                        #46770
                        Ian S C
                          @iansc
                          Hi Ian he proberbly sold them on Ebay,Alan might have just bought it!Ian S C
                          #50086
                          Steve White
                            @stevewhite78094
                            Hi there,
                            further to answers received on this topic, similarly, does anybody know how to correctly size the
                            engine to the hull or vice versa (and prop)?
                            after making a few live steam locomotives, I have a yeaning to
                            build a model steam powered boat of some description, I fancy an
                            Edwardian steam yacht and envisage sedate speed rather than
                            planing!
                            Any ideas on sources for suitable boat plans?
                            Many thanks
                            Steve
                            #50097
                            David Clark 13
                              @davidclark13
                              Hi There
                              Martin Ranson is starting a series on a steam power plant in ME4375.
                              Try the http://www.myhobbystore.co.uk website for plans.
                              regards David
                            Home Forums Model Boats Topics
