Seamus
Seamus
  • #471646
    Tas seamus
      @tasseamus
      I bid g;day to all, as a new member, retired Marine Engineer I have no aspirations as yet for models to build but interested in suggestions. Presently involved in refurbishing a vintage 1949 ML7 from the ground up. Surprisingly very little wear despite age, machine marks still visible on most of the ways. Once up and running then learn how to use as previous experience goes back to Tech School days. Am also looking for a small milling machine to broaden that experience. Lots of info from MEW and members knowledge.
      Tas seamus
        @tasseamus
        New Member from Tasmania
        #471684
        Brian H
          @brianh50089
          Hello Seamus and welcome to this excellent forum. As you probably know, if you have any questions then just ask.
          For a marine engineer, I'm not sure if the Stuart triple expansion engine might be a good idea for a model, but perhaps something simpler to start off with?
          #471704
          David George 1
            @davidgeorge1
            Hi Seamus welcome to the forum. Same vintage as my Myford M Type lathe and just a bit older than me. I have a small Chester mill 16 V and it does me ok.
            David
            #472757
              Welcome to the Forum
              Do you prefer to go by Tas or Seamus?
              Share some pics of your lathe, it sounds a good one!
              Daniel
                @daniel
                Hello Tas Seamus,
                Welcome aboard.
                My brother lives in Margate, Tas.
                ATB,
                Daniel
                #473041
                Howard Lewis
                  @howardlewis46836
                  Welcome to the Forum.
                  Pleased that we have another antipodean member.
                  Ask and ye shall receive! Probably conflicting advice depending upon our prejudices! But ask anyway, and then sift the wheat from the chaff.
                  You'll find a lot to interest you on here, anyway.
                  Edited By Howard Lewis on 19/05/2020 17:09:50
                  #601550
                  Tas seamus
                    @tasseamus
                    Greetings from very cold Tasmania, Can somebodyt assist, require diameters for Myford (early) ml7drive pully's to fit replacements.
                    Regards to all; Seamus
                    #601552
                    Jon Lawes
                      @jonlawes51698
                      Lathes.co.uk
                      You may find what you need on this site.
                      Best of luck
                      #601567
                      Swarf, Mostly!
                        @swarfmostly
                        Good day, Seamus,
                        Welcome.
                        Have a look at the Myford web-site. All the illustrated parts lists (aka 'exploded diagrams ) for their lathes are there in down-loadable form. It's easy to go on-line each time you need them or you could download so you've got the ones you need on your computer in case the Myford site is unobtainable in the future.
                        Once you've done that and studied the exploded diagrams for your ML7, please clarify which pulleys you need.
                        Best regards,
                        Swarf, Mostly!
                        #601571
                        John McNamara
                          @johnmcnamara74883
                          Greetings From Melbourne Seamus. smiley
