Don't use any sealer using acids or alkalies as curing agents. All non-nobel metals corrode when embedded in that stuff! Many Electrical supplies sell a conformal coating spray for electrical switch boxes, or a better type is often available from an Auto-Electrical supplier – often used to insulate/seal alternator/generator windings – typically a red spray. Conventional Electronic conformal sprays are available from places like RS components, etc, but pricey.
If the board is not exposed to temps greater than 80degC, then a decent clear lacquer spray will do the job. Won't last years as will a good conformal coating, but maybe good enough?
Make sure the board is really clean – clean with dishwashing liquid and water, rinse, dry, bake in the oven at 50degC for a while – 20min, and spray 4 or five thin coats from every angle.
Joe
