Sealing boiler fittings
Home Forums Hints And Tips for model engineers Sealing boiler fittings
  • #73384
    Martin Cottrell
      @martincottrell21329
      Hi all,
      I have recently finished building a small vertical boiler and I’m having problems stopping the steam fittings from weeping under pressure. The pressure test was fine because I used blanking plugs in the fitting flanges, wanged up tight with a fibre washer under the heads.
      Obviously the fittings need to be tightened down to a point where they seat in a particular alignment, most importantly the 2 halves of the water sight glass. Although I have used fibre washers under these fittings, varying the thicknesses to get correct alignment when tight, I am still getting seeping under pressure from about 10-15 psi upwards. The fittings are all 1/4″ x 40 tpi. I would like to know does anyone use a liquid retainer such as studlock in these situations to seal the threads or would I be better using something like PTFE tape?
      Advise would be much appreciated!
      Regards, Martin.
      Martin Cottrell
        #73385
          You can buy soft copper washers that come in varying thicknesses, these should give you the adjustment you need to get things lined up. Most ME suppliers will have them such as Bruce, EKP, etc.
          Best to avoid PTFE tape as small bits can get under the seatings of clacks and safety valves. Studlock will be too strong but you can buy liquid PTFE but I would stay with the copper washers
          #73389
          John Baguley
            @johnbaguley78655
            I use Loctite 242 threadlock. Wouldn’t use anything else now. You may need some washers to get the fittings in the right alignment when they are tightened up.
            Windy
              @windy30762
              On my flash steam boiler stainless steel pump valves they are sealed with locktite and hydraulic tested to 3500psi with no leaks.
              Windy
              #73458
              Martin Cottrell
                Thanks for the replies Jason, John & Windy! I think I’ll go for both of the options suggested and use copper washers with a few drops of Loctite for good measure. That’s 2 more items to add to my shopping list for the Bristol ME exhibition this coming weekend!
                Regards, Martin
                #73461
                DMB
                  @dmb
                  You could also use Green Hermetite as a gooey sealer – it never sets so easy to unscrew fittings. Do Not use Red version – it sets solid and hard.
                  John.
                  #73462
                  Ian S C
                    @iansc
                    I use Loctite 567 Master Pipe Sealant, it has a temperature range o -55*C to260*C. It does not lock the thread, so you can undo it easily, it’s proberbly the same as what Windy uses. you could use 569 Hydraulic Sealant. Ian S C
                    #76693
                    Oldpeter
                      @oldpeter
                      On taking my second hand boiler fittings off, I discovered aluminium washers were used, corroding the threads to blazes – will have to replace the fittings with larger ones, Drlling it out and re-tap, but I am not sure in what threads (standard and tpi) the fittings are available – Any suggestions. I have an old Stuart Turner 504 boiler. Also very difficult
                      (? impossible) to find the correct size water gauge or do I have to use one with one free floating end?
                      #76752
                      Ian S C
                        @iansc
                        If you need washers, use annealed copper washers, you can make your own. reanneal when replacing them, after taking the fitting out and putting it back.
                        Aluminium will help prevent corrosion on a asteel boiler, working as a sacrificial annode, zinc is even better.
                        On the cooling system of one of my hot air engines I ended up with a copper hopper for the water, and decided to use some aluminium fins imersed in the water, and exposed to the air for extra cooling. One day I , for some unknown reason, put the volt meter on the aluminium and the copper, result .5 volt, nothing much as current goes. Ian S C
