Sealing between skirting and floorboards
Home Forums The Tea Room Sealing between skirting and floorboards
  • #651725
    JimmieS
      @jimmies
      Any advice on a suitable flexible mastic suitable for sealing between the skirting and floor. A few years I used ? which has gone brittle and now is falling apart. Was thinking of Soudal Acryrub but can't get locally (N Ireland) and p&p is telephone numbers. Many thanks.
      Jim
      JimmieS
        @jimmies
        #651752
        Dave Halford
          @davehalford22513
          You may have to use wooden beading. All the acrylic that I have ever used has continued to dry and shrink.
          #651756
          Paul Lousick
            @paullousick59116
            Expanding insulation foam. Available in a spray can at your hardware store.
            Mask the skirting board and floor with tape and squirt into the gap with the tube/nozzle supplied with the can. Then trim excess after it has expanded and set with a knife and remove tape.
            Edited By Paul Lousick on 12/07/2023 06:35:36
            #651760
            Robert Atkinson 2
              @robertatkinson2
              Sikaflex EBT+ in white or clear. Can be over painted.
              Robert.
              #651764
              John McNamara
                @johnmcnamara74883
                Sikaflex for sure it also sticks very well if the surface is clean, contact the local supplier. Never silicone, it is not nearly as durable, and forget expanding foam for detail work.
                For a nice job mask both sides with tape. apply the Sikaflex to the slot then spray on a little soapy water (if needed) then smooth with a wet finger. finally remove the masking tape straight away while the Sikaflex is still wet. Finally! try not to improve and fiddle with it unless really necessary.
                That's how the professional Caulkers do it.
                Oh! Sikaflex is available in colours.
                Edited By John McNamara on 12/07/2023 08:48:12
                #651830
                DC31k
                  @dc31k
                  Posted by John McNamara on 12/07/2023 08:38:29:
                  …then smooth with a wet finger.
                  That's how the professional caulkers do it.
                  Those two statements contradict each other.
                  No professional uses digital smoothing.
                  For domestic use, Fugi tools or clones are more suitable.
                  #652106
                  JimmieS
                    @jimmies
                    Many thanks for all replies which are greatly received. Jim
                    #652185
                    Bazyle
                      @bazyle
                      Foam carpet underlay.
                      #652191
                      phillip gardiner
                        @phillipgardiner
                        Selleys butyl mastic skins but remains flexible for years,.
