Russell, I drew out a few styles before I got the shape I wanted, and they had to be the correct length from the centre to the outer line of the chapter ring,
To stick the template down, I first give the steel a good rub with 180 grit abrasive paper, then wipe it over with lighter fuel to degrease it, then spread the area for my template with fast drying liquid superglue, not the thick stuff!
You need to do it outside ideally because the vapour is a bit grim if you get a whiff, and the heat it generates is awesome, so keep you fingers off it,
I usually wipe the paper over with a lolly stick or something similar, enough to ensure the paper is stuck down all over and to squeeze out excess glue, I used a bit of scrap cotton cloth once, but the bugger stuck to the paper and I had to start over again, fortunately I'd scanned the template and saved it in my 'Clock Hands' pattern folder, so all I had to do was print off another, I'd recommend anyone do that!
If (when) the paper does come off during cutting, which it will when you get onto the thin neck of a hand, just put some more glue on it and dab it down!
Make sure you cut on the waste side of the line too, you can see I got a bit too close on one bit where I wasn't paying enough attention, which meant some extra filing to get the shape back, fortunately the neck was a bit on the thick side, the rest is 'eyeballed' once the paper is removed!
Derek, to put a link into a posting, if you look on the top toolbar, the third icon on the bottom row is the 'insert link' tab, it will open another box where you can paste the url, just open the photo you want to use and copy the web address shown in the browser address bar, there's also an insert image from album' icon which i missed, it's the camera icon on the top row.
No disdain about the fibre optic clock BTW, I'm watching it with some interest even though I've no real interest in electric clocks (I'm a bit of a luddite and would make a clock the old fashioned way without jewels just because I can)
I just stand back in admiration anyway of everyone who is able to dedicate the time to their project whatever it is!
Edited By RJW on 02/02/2013 17:38:12
