Posted by Iain Downs on 17/11/2019 10:22:05:
Today I had another go at cutting screws on the lathe.
So today, I took some steel bar (sadly sourced from b&q and likely entirely inappropriate for model engineering) and attempted to put a 1.5mm thread on it. It is 11mm stuff and I turned it down to 10mm.
Am I doing something wrong, or is this about what you would expect?
Iain
I think you've already identified the chief suspect – B&Q Steel!
When I first owned a mini-lathe I wasted a good few months attempting to turn scrap and DIY Store metal. I foolishly assumed that a metalworking lathe would cope well with any metal. This is a serious mistake!
There are about 2500 different steels available and many of them do not machine well. Some don't machine at all. Similar with the many Brass and Aluminium alloys about – although many machine well, some are downright difficult.
My experience of DIY Store metal is that it is poor stuff intended for decorative and rough work not engineering. The aluminium is soft and sticky. The steel is hard and gritty. Brass is reasonable, but not good compared with others. Most of the metal I initially played with came from B&Q, but I can confirm other stores are equally unsatisfactory.
When I finally got round to visiting my local metal emporium and telling the nice man I wanted steel to machine it, he sold me some EN1A Pb. Enormously easier to work with than B&Q's unsuitable stuff. Same with Aluminium alloy and Brass. Now I avoid metal unless I know what it is and although I experiment with scrap, I will walk away rather than persist with an unlucky choice.
Although it's better than DIY Store metal, worth knowing that ordinary mild-steel doesn't machine particularly well either. It's OK rather than brilliant, which is why EN1A is popular!
When you're a self-taught beginner, trying something a bit tricky like threading for the first time will go certainly go badly if the metal is carp! My advice is to learn threading on some Aluminium or Brass bought deliberately because machinability is mentioned in the specification. Both metals are easier to thread than mild-steel and good to learn on. Aluminium is cheaper, but needs to be kept wet with WD40 or paraffin. With a bit of experience it gets easier to handle difficult materials in the workshop, but you need to develop a feel for getting the best out of your machine. This is particularly true of small tools – big powerful machines can often cope with sub-standard driving.
