Kwil, thanks for the reply. Ive just waded through the Sandvik Coromant threading PDF, and it says in there that you can use a R/H insert to cut a L/H thread as long as the shim is changed to a negative one. Conversly, you can cut a R/H thread with L/H insert, provided you use a positive shim !.
Certainly saves buying both types of insert, just 2 different shims.According to the blurb, using the "wrong" insert may cause insert movement at the beginning of the thread, so care is needed. Thats what it says anyway. Cheers.
