screw size problem
screw size problem
Home Forums Beginners questions screw size problem
  • #768744
    pgrbff
      @pgrbff
      I’m in Italy so finding imperial screws not very easy. I am trying to determine the size of a threaded hole on my tablesaw, an old Startrite before ordering some screws.
      I bought a range of screw size checkers recently but as luck would have it none fit.
      A 5/16 18 or 24 will go in but is clearly too small. A 3/8  16 or 24 is too big.
      What is there in between these two?
      Nigel Graham 2
        @nigelgraham2
        I think Startrite is American, so the screws are likely to be of inch dimensions but AN / UN standards.
        #768755
          On pgrbff Said:
          […] A 5/16 18 or 24 will go in but is clearly too small. A 3/8  16 or 24 is too big.
          11/32
          But they are rare !
          … I would recommend taking a cast of the tapped hole, and measuring it carefully before proceeding further.
          David Jupp
            @davidjupp51506
            This web site might possibly help
            https://startrite-spares.co.uk/
            #768775
            Martin Connelly
              @martinconnelly55370
              I would get a wooden dowel of about Ø6 and see if you can screw it in. A suitably sized dowel will then take the form of the thread and when unscrewed can be checked with a scale or screw gauge to find what the TPI or pitch is. Knowing this will make it easier to figure out what the thread is. It does not have to be a tight fitting dowel, just slightly larger than the bore of the hole. Even a wooden pencil that is thinned down a bit will do or a square section of wood with a diagonal dimension that is about 6mm.
              There are some screw forms in the standards that can be made into non-standard but still listed threads, I have recently made something with a 1/2″-16 UN thread (I had suggested a 1/2″ BSF thread but the designer wanted a UN form to match other UN form threads that were used at different diameters including a 2 1/8″-16 UN thread). Out of curiosity I tried a 1/2″-16 UN thread nut on a 1/2″ BSF rod and it fitted however trying the opposite, 1/2″ – 16 UN tap in a 1/2″ BSF hole it did not fit.
              Martin C
              #768778
              David Jupp
                @davidjupp51506
                Have you tried M8 ?
                #768780
                pgrbff
                  @pgrbff
                  Martin C
                  6mm goes straight through. I tried M8 dowel but couldn’t get a impression.
                  #768781
                  pgrbff
                    @pgrbff
                    I have already looked, no sizes, unfortunately. It doesn’t even show the item I need.
                    #768795
                    pgrbff
                      @pgrbff
                      On David Jupp Said:
                      Have you tried M8 ?
                      too small but sort of matches threads
                      #768800
                      Clive Brown 1
                        @clivebrown1
                        If you’re refering to the thread pitch then M8 is very close to 20tpi which is common in imperial thread standards.
                        #768806
                          11/32
                          But they are rare !
                          Not sure what, if anything, this proves … but
                          https://toolz4you.co.uk/product/11-32-x-22-tpi-whitworth-form-1-5-16-od-die-ed594/
                          ChrisLH
                            @chrislh
                            Is it possible that the thread in the hole is stripped ?
                            #768823
                            Grizzly bear
                              @grizzlybear
                              Hello,
                              Have you got an identical screw on your machine that you could remove and photograph against a steel ruler?
                              Good luck………..
                              #768827
                              Martin Connelly
                                Not getting an impression on the 8mm dowel makes it sound like it is a stripped 5/16″ as Chris is thinking, is it in cast iron? It may be possible to Helicoil it to match the rest of the machine or to cut the next size up thread and fit a larger screw. A quick check on EBay shows reasonably priced 5/16 UNC and UNF Helicoil type kits are readily available. Is there someone near you who works on older cars or bikes with UNC threads?
                                Martin C
                                #768860
                                JohnF
                                  @johnf59703
                                  Hi Maybe this will help, lots of obscure threads here   https://www.gewinde-normen.de/en/index.html
                                  I like Grizzly’s idea find another screw on the machine to aid identification.
                                  Another possibility is turn a dummy from soft material, alloy or lead slightly over the minor dia with a taper on the end and screw it into the hole — hopefully it will form a thread on the dummy,  the best way is use Woods metal to cast a pattern.
                                  larry phelan 1
                                    @larryphelan1
                                    I have a Startrite bench saw, so might be able to help.
                                    Where is that screw located on your machine ?
                                    #769307
                                    mark smith 20
                                      @marksmith20
                                      Startrite are british as far as i know ,i have a mercury pillar drill. Theres a tablesaw manual on vintagemachinery .org  but doesnt mention the screw types in the parts lists.
                                      #769316
                                      Robert Atkinson 2
                                        @robertatkinson2
                                        You could also use the nearest size helicoil* insert for either a metric or imperial replacement screw. This is a good option if there is a chance the existing thread is damaged. You can get low cost tooling if just doing a few inserts.
                                        *other thread repair inserts are available…..
                                        #769507
                                        Yngvar F
                                          @yngvarf
                                          I recently got a Startrite 275. There is a lot of metric fastners on it for a british machine from the sixties.
