To be honest if the tailstock barrel itself is not fully concentric there’s precious little I can do about it. The most likely cause is probably wear, particularly from tools like drills slipping.
Anyway I set up an indicator on the tool-post, despite sparse equipment for doing so. This showed a run-out of 0.002″ on a piece of ground bar in an ER collet, and the same error on the collet chuck body itself, giving some limit of accuracy for measuring the tailstock.
I cannot measure the tailstock barrel bore, only the outside of the barrel or some point on the protruding part of a centre. However, the outermost part of the barrel is least likely to be worn because it rarely goes inside the casting.
Next I mounted the DTI via two bits of aluminium-angle on the faceplate, projecting enough to just reach the barrel extended over the saddle. With the rear tool-post and top-slide removed for access I could swing the rather ungainly assembly perhaps 150º, giving something like that three-point test.
This proved first that despite careful adjustment of the tailstock’s slide there is some lateral swing due to giving it enough play to set the unit at the end of the bed: the vertical surfaces of the bed are worn in their central section. The tailstock starts to grip at its furthest forwards position. The lateral play is probably only about 0.001″ but produces enough yaw to affect significantly the centring at further extension.
Moving onto the lateral adjustment itself, I succeeded eventually in bringing the measured error down to about 0.002″, on opposite sides of the barrel (being careful not to catch the DTI probe in that keyway).
I tried it on two or three centres of varying lengths and possible wear-and-tear, but mainly measured on the barrel itself slightly back from its muzzle.
I left it for the evening at that point, but the next stage will be more turning tests. I will probably repeat the test for bed twist but the result I obtained yesterday suggested I have set the bed level (by lathe-levelling definition).
I have a Rabone-Chesterman 6″ engineers’ level, which is part of the “book” method, but whether it is sufficiently sensitive is another matter. The bubble is somewhat shorter than the space between the 2 marks, but I can test its relative sensitivity by feeler-gauges and surface-plate – possibly the milling-machine table. The sensitivity specification is 0.003″ or better per foot but I doubt this level is readable to such limits.
I’ve also a Wixey digital level but it’s not the most inspiring looking thing, from its small spirit-level that appears to have given up the ghost to three discs in the underside that might function better as surface contacts (if they are that) if they were not slightly recessed into the instrument case. Still, it may work as a comparator. And whilst the instructions are not quite the King’s English, I must admit I cannot read Mandarin.
The Myford manual though does give two further tests for level, one using a DTI and a bar in the chuck, the other by turning two collars on the bar.
It would appear trying to fettle an old lathe that may have had a rather unhappy past is a matter of trying to play several unexpected sources of inaccuracy against each other towards a rather unsatisfactory compromise. While though feeling somewhat better myself than I did last week, realising the desperately, ridiculously slow progress and rough quality of my magnum opus steam-wagon – itself now over than 20 years old and its entire project over 40 – was sharpened by realising my own progress as a septuagenarian having lost no less than three long-standing friends within the last two or three months – and a fourth last Thursday.
Very likely, this poor old Myford ML7 lathe is like its owner…. well past its best!
