Helping someone who had bought a ML4, I produced a fine feed for him, using extra gears.
The set up was 20:60/20:60/20:60 This gave a fine feed of 0.0046″/rev
He lacked the studs, so I made those, filing away one end of the stud placed nearest to the Spindle, and fettling the slot in the Banjo, to allow the entire train to mesh with a little backlash (A piece of paper fed into each mesh, starting at the Leadscrew end, and finally swinging the Banjo for the the mesh with the 20T on the Spindle.
He also lacked sufficient gears. A 60T from a ML7 was modified by drilling a 3/32″ hole for the pin, using one of the other gears as a jig. (Unfortunately, to do this the “jig” had to have the pin hole drilled right through). The ML7 60T was drilled opposite the keyway.
Despite have a full set of Changewheels, he had no interest in screw cutting; just wanted a fine feed.
To keep his costs down, I made him a couple of 20T gears
