scratch build
scratch build
  • #351075
    tony pickstock
      @tonypickstock54498
      hi im tony from north wales
      ive just started with a mini lathe, milling machine, metal saw, sand casting
      all the gear no idea, ive played around shredding my plastic gears to understand the machines, i have now put metal gears in , ive made a few pistons and cylinders to understand the functions, im now going to make a vertical engine , ill tak pictures of my progress and failures
      tony pickstock
        @tonypickstock54498
        steam engine
        #351200
        David George 1
          @davidgeorge1
          Hi Tony Welcome to the forum what machinery do you have there is plenty of help if you need any and pictures of progress and finished projects are welcome.
          David
          #351205
          not done it yet
            @notdoneityet
            I’m not too sure what you might call as ‘scratch’. I understand that to be from start to finish – ie design and build as you go.
            I would recommend following a well tried design as a first project.
            BTW, welcome to the forum.
            #351207
              Look forward to following your progress, just ask if you need any help with design or construction.
              J
              #351208
              geoff walker 1
                @geoffwalker1
                Hi tony,
                I lived in north wales for over 30 years, still miss the area a lot.
                Where do you live?
                Sand casting sounds interesting, are you setting up a mini foundry?
                good luck with future projects
                Geoff
                #351233
                  Hello Tony,
                  Welcome to the forum.
                  tony pickstock
                    @tonypickstock54498
                    Hi guys, thanks for the welcomes , well first off I blew my motor on the lathe , armadeal called Hugh and got one the next day very helpful guy, I'm planning on building a twin cylinder Stewart design , making my own patterns and casting in alluminium, I have a small electric kiln which is ample size for the size of casting I plan to make
                    #351601
                    mechman48
                      @mechman48
                      Welcome Tony
                      ​Look forward to seeing your projects / progress.
                      George.
                      #351611
                      sean logie
                        @seanlogie69385
                        Welcome Tony …looking forward to your build
                        Sean .
