Now here’s a familiar topic! I too built the Jan Ridders engine from the plans in ME and, although I can get it to fire it just won’t keep going. I put it aside in frustration several months ago but am thinking of getting it back out and having another go. I also have a half-scale Hercules Economy engine from LE Services and have had the devil of a job to get that going as well, so far it will start sometimes, usually only when its cold (!) but I cant get it to run for very long before petering out and I cant yet get reliable starting. It’s just the same on Butane. Then there’s the governor to set up – not even gone there yet.
I have been thinking of the Scott engine recently since, like you Norman it looks quite easy to construct etc but, I really do need something which works so I am having second thoughts now. There will be one at the Bristol exhibition next month on the Poly stand which I shall have a look at but I’m getting a bit put off now.
I do find there are any number of builders like us with similar problems so it would certainly be helpful if others who have gone through the same traumers and have succeeded in the end, to tell of their experiences. The only trouble-shooting gen I see just covers the usual; “make sure the spark is OK, check the timing carefully, make sure petrol is getting to the carb, check the valve seatings, check for leaks around the head etc” all fairly basic stuff but I guess there can be a lot more to the subject.
I’m looking out for a ‘real’ open crank hit and miss engine at the moment, just so I have at least one engine which works and I can play with whilst soldiering on with the home builds.
Ian, I firmly agree about needing patience with Stirling engines and it looks like similar patience may be needed with i/c’s as well. Lets all keep at it though and I, for one, will certainly report any successes on this forum.
All the best
