the workability of the SS depends very much on the grade – the easiest way of cutting a bar is with an angle grinder fixed in some rigid frame and using a 0.8mm cutting disc – Aldi currently has a cheap holder for their Workzone small angle grinders (tho it can be made to fit B+Q’s small angle grinders) which is use-able (just) for cutting up to 25mm bar (maybe 32mm at a push) but depending on your lathe and tooling working it on a small lathe may be difficult as most SS work hardens on sight of a lathe tool and any hesitation in feed can be fatal to future work – found very sharp HSS seems to work for me though have used insert tools to remove the saw marks from the original cut so can use small lengths as bases or as knobs.
I got my small end of bar offcuts from the ‘waste’ bin at my supplier – usually 316 I think – they cut bars using a high power saw with plenty of coolant – its not cuttable (the blade jams and on one sample snapped) with my small bandsaw tho that can dry cut up to 90mm bar of steel .
Edited By Frances IoM on 12/10/2016 14:12:21
Edited By Frances IoM on 12/10/2016 14:16:17
