Clive's answer makes good practical sense. But if you are scaling the bore, will you not also be scaling the crank throw, along with all the other dimensions? In that case, the swept volume will change as you scale the bore. It will change again if you scale the crank throw. Swept volume = 3.14 x diameter x stroke (or throw), so scaling by 1.5 multiplies the swept volume by 1.5 x 1.5 = 2.25
If you just want to scale the volume by 1.5, you would either need to keep the stroke the same as the 5" model, and multiply the bore by 1.5 or leave the bore the same and multiply the stroke by 1.5 (which you probably need to do if you are scaling the other linear dimensions). Intuitively, it seems wrong to scale one dimension without scaling the other. Then what about the dimensions of the valve gear? Surely that requires everything, including the stroke, to be scaled by 1.5. Then there is the power, which must depend to some extent on the swept volume, suggesting the bore and stroke should both be scaled. Surely the volume of the boiler will increase as its diameter and length are both increased, suggesting you would need a scaled bore and stroke to cope. It starts to get complicated.
Which is why Clive's advice seems sound.
Marcus
