Hello Dave,
I tried to do much the same but it finished in tears I'm afraid. I found another way round it after that experience
You will need to boost the scale all round for a bigger relieving throw to about 0.075 inches from the design value of 0.030 inches.
The eccentric throw can remain the same if you are making a 12 tooth cutter. The areas that need beefing up are the indexing pawls and the sections of the pieces that rotate within each other. Bushing and brass bearing interfaces are essential to avoid 'pick up' and I recommend using gear oil for lubrication of at least EP 80 grade
I also recommend gripping the drive boss in a chuck rather that trying to turn between centres
Wishing you well and looking forward to reading an article on how it went for you
Regards Brian
