In my idle moments I’m sketching up re-dimensioned plans for a 1.5x Vega V twin glow ignition aero engine. It will never be ‘flown’ but hopefully will actually run. The original design by David Parker (Model Engineer Jan 1986 onwards) was for a 9cc engine and scaling everything up by 1.5 times would give a 30cc engine. The original timing gears are 48dp 12T and 24 T which gives 0.75″ between centres. To get 1.125″ between centres for my bigger engine I could keep the tooth count the same and go for 36dp or alternatively I could stick with the 48dp and go for 18T and 36T. Is there any advantage in either solution?
FWIW both combinations of gears are widely available in hardened steel for the radio control car enthusiasts and only a few pounds each, I probably won’t be cutting them myself.
