Ah, my 267th post! Which will mean nothing to anybody but me, as 267 is the competition number on one of my gliders!
John: Actually no, I’m interested in what sort of rpm the rear wheel might do, not the speed of the engine in mph per se. Although of course the two are connected, and you’re spot on, the rear wheels are 2 feet in diameter.
Jason: Thanks for the information, and for reminding me about the TE forum. I am a member there, but don’t post much. I don’t know enough to make intelligent posts! The consensus seems to be about 500rpm for the engine and about 50rpm for the rear wheels, give or take.
The reason I ask is because I’ve boo-boo’d on machining the final gear castings, which are 14.8″ in diameter. The periphery and bore are concentric to within a thou or two, but the side of the gear has a slight wobble, about 20thou. This won’t affect the mesh of the gears, but I wondered if it will be noticable as the wheels rotate, and should I try and do something about it.
Also, in true parliamentary fashion I feel entitled to ask a supplementary question. I am intending to use cast iron pistons, and was going to make cast iron rings, but John Rex recommends bronze rings. What do you think?
Edited By Andrew Johnston on 11/01/2011 20:51:07
