Sanding Belts for 4×36 Machine
Home Forums Workshop Tools and Tooling Sanding Belts for 4×36 Machine
  • #765351
    William Chitham
      @williamchitham75949
      I have inherited a basic Clarke belt/disk sander which I thought would be useful for metal and woodwork but the belts, which probably came from Machine Mart, have a pronounced lump at the seam so that there is a horrible hammering effect each revoulution which makes it very unpleasant to use. Can anyone recommend a better quality belt that will run smoother?
      Thanks, William.
      bernard towers
        @bernardtowers37738
        Take them back, I did and got a refund and now buy from anyone else
        #765365
        Plasma
          @plasma
          Yes there are plenty of abrasive belt suppliers out there. A Google search will provide plenty of options.
          #765387
          KenL
            @kenl
            I had a similar problem so purchased some silicon carbide ones from Amazon a few months ago, they were excellent with barely detectable joints.
            EDIT
            Link not working so search on the following
            Sruhrak Sanding Belt 100 X 915mm- 12 Pcs Silicon Carbide Sanding Belts
            #765628
            William Chitham
              EDIT
              Thanks Ken, nice to get a specific recommendation, I have ordered a set. I might try one of these much pricier 3M 800 grit belts for finishing and sharpening in due course:
              https://www.multitoolproducts.com/product-page/grind-belt-915-4×36-trizact-237aa
              William.
              #765639
              Taf_Pembs
                @taf_pembs
                I am in the process of upgrading my old Clarke CS4, the motor let the nasty smoke out (I’ll put a couple of pics up when I’ve finished it).
                I ordered a pack of 10 Zirconium belts from Abtec Abrasives a long time ago, about 10 years (I think it was their own brand or unbranded). I don’t know what their prices are like now but it was a really good deal then. They not only did over 2 1/2 thousand Rhodesian teak 9″x3″ hardwood parquet flooring blocks on all 4 edges and the face I had for my house build but I am still using them, I can not fault them.
                Be careful using it as a belt grinder, it will do it but go easy on it. Maybe your motor is more powerful than the 1/3hp that was on the old one I acquired but  if you slow it down too much when grinding it will switch over to the start windings and will soon burn out .. which is I think what happened to mine unless it was just that it was probably as old as me!
                #765711
                bernard towers
                  @bernardtowers37738
                  +1 for Abtec Abrasives they  are really helpful and prices are reasonable. Just a satisfied customer.
                  #765741
                  JohnF
                    @johnf59703
                    Another plus 1 for Abtec I have used them for years and very satisfied with the products.
