I have found that it very much depends on the material to be sanded, if you are into scratch building model airplanes then the cheap ones are adequate but not for metalwork which is where the genuine ones come into their own. I also find that speed is a good destroyer of these as the generated heat has nowhere to go as the rubber drum is not a good heatsink.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
