So, it's a cold clear day here, high was -14c, and yours truly decided to make a "D" bit in the basement workshop, with oil hardening silver steel. On the floor, with a fire brick or two, a plumbers propane torch, and the tub of oil. No workshop shed outside, no garage, just snow and my large torches packed away for the winter.
Fortunately the wife was at work; and the smoke detectors did not go off, but the hardening was not good enough. Had the doors open for a few hours getting (hopefully) enough of the smell of the oil quench out of the house – now letting it warm up…
Short of mail-ordering in a 9/32 dis HSS blank and grinding it, is it "ok" to make the valve ball chamber with a drill bit, not a "D" bit? The angle that the ball sits in will not quite be as sharp as with a D bit, but does that matter?
It won't be warm enough to do the hardening outside for a good few months yet…
John.
