Safety lamps for the lathe
Home Forums General Questions Safety lamps for the lathe
Viewing 6 posts - 26 through 31 (of 31 total)
  • #68256
    Martin W
      @martinw
      Hi
      Another place where LEDs etc can be bought at reasonable prices is Phenoptix . I have used them for some bits a while ago and they were very good; usual disclaimers re vested interests etc.
      Martin
      NJH
        @njh
        GU 10 UPDATE
        Well I have purchased some “21 SMD LED” lamps with a GU 10 base. They are quoted as the equivalent light output of a 50W halogen lamp but actually using only 3.2W. The stated life is 12 years – we shall see! Instant on and cool – satisfactory in all respects – price makes one cough a bit but I was getting through the halogens at an alarming rate so maybe not too expensive in the long run. I’ll try these LED types for a bit before replacing all the others.
        I envy all you visitors to Harrogate but, as it would be a round trip of over 600miles for me, I’m afraid I will not be seeing you there!
        Norman
        Edited By NJH on 11/05/2011 14:43:13
        #68269
        The Merry Miller
          @themerrymiller
          Norman, who was your source of supply for the LED lamps?
          #68276
          PekkaNF
            @pekkanf
            Posted by John Corden on 07/05/2011 19:05:44:
            These might suit:
            Very white light, stable gooseneck and no heat.
            Edited to add: major dia of lamp is about 35mm. You can use the supplied base or fix the gooseneck to any convenient surface.
            Edited By John Corden on 07/05/2011 19:08:40
            Bought one of those with a clamp. Just to be “sure” I put it on for a breakfast. It worked three minutes. Very disappointed on chinese quality.
            PekkaNF
            #68280
            NJH
              @njh
              Hi Merry Miller
              I have sent you a private message.
              Norman
              #68281
              John C
                @johnc47954
                Pekka,
                Maybe just bad luck – mine are still working OK. Or maybe it was your breakfast………
