No goves, no rings, safety goggles, if nasty chips faceshield material to keep it away, use apron and rubbish drum underneath with guided plastic.
Had the chuck & toolpost keys wired safety in special places(series with doorswitch), so if these tools are not there, the lathe cannot run, or switched off if pulled while its running.
When I lifted my 330 Lathe height initially(200mm) on advice from machinist, I installed the lathe between a metal frame box over it.
I then fit a 40mm pipe between front upright pillars to protect me from bumping the lathe apron in garage when not in use. I made it to easuly remove. Till today I actually never removed this horisontal pipe at your waist height.
I now sort of lean/stand against it, and if I remove it, it feels like I walk into the lathe. I understand with big lathes or smaller ones this would not be practical to do.
