On 15 December 2024 at 18:54 JohnF Said:
On 14 December 2024 at 18:18 SillyOldDuffer Said:
Also, avoid soft metals like Aluminium alloys. Their problem isn’t lack of strength, it’s that they tend to distort and stick in the hole …
Well I would disagree with you here Dave, Emco lathes (Super 11) are fitted with an alloy shear pin on the feed shaft from the factory, I made some replacements from alloy rivets, no idea of the original spec but it is a soft alloy thus me choosing rivets as the material. Anything stronger would be inappropriate and probably cause damage. Its better too weak than too strong !
Agreed it’s better for shear pins to be too weak rather than too strong! But, as is common in engineering, the optimum is some sort of balance, here between a pin that won’t break when the lathe is working normally (a pain in the proverbial), and a strong pin that doesn’t break at all.
We’re both at a disadvantage compared with EMCO’s designer. He will have known pretty much everything about the machine: power, materials, normal loads, breaking stresses etc, plus experience of lathes and how they wear and break in practice. Makes it possible to choose the diameter and material needed to shear at a known load. The rest of us have to guess!
Selecting rivet metal for shear pins on the basis that EMCO used an unknown alloy on one of their lathes feels a bit of a stretch to me. But John’s guess is as good as mine! I pointed out though that metals that expand into holes when hammered won’t be as easy to remove as a harder metal.
Also beware assuming a metal’s malleability with weakness. Rivets can be tough – depends on what they are made of, and their intended purpose.
Brass, I think, is a safe compromise. Weaker than steel, unbending enough to punch out cleanly, and easy to drill out if it comes to that. Common too: “any old Brass” is much easier for Bernard to source, compared with “an unknown alloy rivet of the type John chose”.
I don’t think shear pins on Far Eastern hobby lathes are fussy though. Just avoid steel, especially tough guys like roll-pins and dowels!
