Ryobi RBC26SESB
I pulled this previously useful little machine out of the shed today, to tidy-up the wild garden: Assembled the lower shaft onto the upper, and fired her up.
The motor runs fine, but there is no drive to the cutter-head
The [straight] lower shaft has a flexible drive with a square end (like an overgrown speedometer cable) and functions correctly BUT there is no drive to the square socket in the upper section. …
Normally the shaft remains still at tickover, and then engages as the revs increase: This is presumably the action of a centrifugal clutch, and I can only assume that the clutch is broken, faulty, or worn-out.
The machine is [predictably] just out of warranty, but has only done a few hours actual work.
Before I start investigating … Does anyone have experience of this problem and/or access to an 'exploded diagram' ?
Thanks
