Well 157 views an no reply so either nobody is interested or they all can’t make out teh drawing.
Having looked a bit more I would say
Chimney flange should be hidden detail and also shown on the side elevation
Bottem left view is just wrong not sure if its teh original, scanning errors or the Greek effect.
The 9mm dimension line should be drawn to the edge of the main Furnace not the edge of the “band”
The 39mm dimension lines should go to the edge of the band giving a 2.5mm band width all round
The 40.25mm dimension lines should go to the centres of the 8BA holes
David perhaps you could confirm my theories?
While you are at it the pump piston is 6mm into a 6mm bore in the text but 5.5mm into a 5.5mm hole on the drawing (Fig 29) Is the 6BA thread onto a 2.5mm shaft correct seems it won’t give a lot of thread depth.
Wooden base should have a 60mm dia recess not 6mm and the square hole for the post should be 10.5sq not 5sq(Fig 32)
J
