Rust Stain on STONE
Rust Stain on STONE
Home Forums Materials Rust Stain on STONE
  • #29487
    Carl Jebbs
      @carljebbs45381
      Give me a suggestions on how remove this stain..
      Malcolm Bannister
        @malcolmbannister38996
        Try something like Kilrok kettle descaler from Aldi. It's formic acid based. Try it on a small area first and DON'T use it on marble or limestone.
        Hope this helps.
        #190131
        Capstan Speaking
          @capstanspeaking95294
          Builders' brick acid will do it.
          #190135
          Muzzer
            @muzzer
            Posted by Capstan Speaking on 16/05/2015 13:18:49:
            …which is hydrochloric acid, I believe. Or "muriatic" acid as the Mercans like to call it.
            Dunno if it works on rust or not myself.
            #190147
            Brian Wood
              @brianwood45127
              Oxalc acid is the correct material, available in small packs of 1/2 kilogram at sensible prices from various outlets on Ebay.
              Usual precautions apply as it is poisonous if ingested. Present in rubarb leaves for example, not to recommended as part of your 5-a-day!
              Mix in water and apply, bad staining will need retreating
              Brian.
              #190150
              Capstan Speaking
                Posted by Muzzer on 16/05/2015 13:32:39:
                Yeah, I had an old Sky dish rot onto concrete. You couldn't tell afterwards.
                #190183
                  Can anyone see the original question?
                  I can't and I can't see why…
                  Capstan Speaking
                    It's in the sub title. The chap's a forum noob. He's ok, it's not like we're Linux geeks wink
                    #190193
                      No, I noticed that earlier, its an older thread as its numbered about 85,000 and we are now on 107,000?
                      Edited By JasonB on 16/05/2015 20:52:41
                      #190195
                        Dates from June 2013, guy who posted started this and one other thread, think he may have been a spammer. Looks like the post was deleted but not the thread. For some reason Malcolm has decided to answer it anyway
                        Carl Jebbs if you want to look it up Neil
                        Edited By JasonB on 16/05/2015 20:54:55
                      Home Forums Materials Topics
