Rust Protection
Rust Protection
Home Forums General Questions Rust Protection
Viewing 25 posts - 1 through 25 (of 61 total)
  • #565934
    Chris Suddell
      @chrissuddell31348
      Hi,
      I'm having a bit of a nightmare keeping rust from forming on my Lathe and Mill both Warco.
      I only use them once a month and every time I go back to them rust has formed.
      I have used anti corrosion oil over winter and during this summer with a duvet covering them at night.
      Apart from two vices all other steel items in my garage are rust free.
      I'm a little miffed. Any help would be nice, I don't want them getting really rusty bad.
      Chris Suddell
        @chrissuddell31348
        #565940
        Journeyman
          @journeyman
          The best solution for rust prevention is to maintain constant environmental conditions. This can be achieved in a well insulated workshop with a modicum of background heating in the winter. Rapid temperature changes will encourage condensation on cold machinery.
          My equipment Warco WM250 lathe and WM14 mill have been in my outside timber workshop for 14years and do not get any rust. No special treatment just ordinary oiling and no covers. Workshop is home-built has 2" rockwool in the walls and 4" in the roof. Background heating from a thermostatically controlled fan heater. Temperature maintained at about 10degC. When it gets cold RH remains at about 50%.
          I should add that the workshop is multi-use and gets to store my bike even if it is wet from a ride so no special care taken to prevent moisture. I even have a sink and wash all sorts including hands. The 3D printer doesn't like it when it gets cold and I store filaments in a box with silica get to maintain 30-40% RH which is how I know that the overall workshopl RH is generally higher.
          Edit: add para
          Edited By Journeyman on 07/10/2021 14:06:24
          #565941
          KWIL
            @kwil
            Chris, the use of a fabric cover is not a good idea, they tend to atract moisture from the air.
            I kept lathe in an unheated wooden shed with no insulation for around 20+ years just using oil on all bare metal, little or no rust problems as I recall. Still have the lathe, some 40+ years later and still no rust, but is now in a heated workshop.
            #565944
            Dave Halford
              @davehalford22513
              As above, loose the duvet. It seems like a good idea, but isn't
              #565945
              Bo’sun
                @bosun58570
                I use a desiccant dehumidifier with a constant drain and it works well for me with a little surface oiling from time to time. I prefer the desiccant type to the refrigerant type because they seem to work better at lower temperatures.
                #566082
                Howard Lewis
                  @howardlewis46836
                  HTH
                  For rust to form there must be Oxygen and Water (Moisture )
                  If the air is above the dew point, moisture will not condense on a cold surface.
                  Alternatively, if the relative humidity is low, condensation is less likely.
                  Summing it up, ideally; keep the air dry (Dehumidifier ) and above the dew point (Heater, but dry heat, NOT combustion , unless the products of combustion are vented directly outside.
                  What can t you do/
                  Insulate the shop. (My small wooden shop has 50 mm glass fibre in all walls and the roof. A 2 Kw fan heater usually runs for about 15 mins before the thermostat shuts off. Then, it runs for about ten minutes in each hour. But my shop is small and in UK, East Anglia.)
                  Ventilate; with a vent as low as possible. Moist air is heavier than dry, so a low vent allows it to go outside.
                  (Church walls without a damp course are kept dry by unglazed tubes set into the wall so that they slope downwa towards the outside.&nbsp
                  This implies a high level vent to allow air in to replace the moist air that goes out through the low level vent.
                  (My shop has two small fixed vents at floor level and a high level intake for an intake fan, with an external hood open at the bottom to exclude rain. )
                  As said, dispense with the duvet, since this may retain moisture.
                  The old, uninsulated, shop, the oil on the Myford was often milky and emulsifying with moisture. The insulated shop, rust is almost unknown. In winter, a 60 Watt tubular heater under the bench is left on and after a couple of days the steel benches are just warm to the touch,
                  So ventilate, keep as dry and as warm as possible.
                  #566088
                  Baz
                    @baz89810
                    Totally agree with Bo’sun, I keep a desiccant dehumidifier running in the workshop, a single skin brick double garage and have no rust problems. I did have a refrigerant dehumidifier but it froze up solid every winter. A bonus of the dessicant type is that you get a bit of warm air out of it, every little helps!
                    #566093
                    Brian Morehen
                      @brianmorehen85290
                      Have you tried a Hessian Sack I have used mine for over 40 yrs no problen , May be because you can see through the the woven sructure if you hold this up to the light . If you can find one today?.
                      Bee.M
                      #566100
                      Bazyle
                        @bazyle
                        I think a duvet is too thick and cannot breathe so it will be perpetually damp. Just a cotton sheet works best.
                        If you have replaced some of your old incandescent bulbs with LEDs recently like you should have rig say two 60W bulbs in series in the cabinet under the lathe. In series they will reduce to just a few watts each. this will mean teh lathe is still cold but it is hotter than anything else, so should push the moisture away to your other tools.
                        #566102
                        not done it yet
                          @notdoneityet
                          My small (up to 8 litres water collection per day at full power) desiccant dehumidifier consumes approx 375W on its lowest setting. I only run it for a couple hours each night most of the winter. Three when quite cold and occasionally four if very cold. I do sometimes need extra warmth when in situ, but not too often and not much when I do.
                          I invested in insulation and draught-proofing which saves me as much as a tenner a week (compared to how Baz runs his dehumidifier) – although it would turn off when down to its set humidity level.
                          Three hours per night costs less than a quid per week, which I reckon is cheap to protect my machines
                          At current leccy prices it would cost ~£2 per week if it ran during the day for those three hours.
                          #566155
                          bernard towers
                            @bernardtowers37738
                            I have 5 machines in an unseated and uninsulated garage but don’t suffer with rust problems, I put it down to using hyd oil as a cutting lube.
                            #566157
                            Alan Charleston
                              @alancharleston78882
                              Hi Chris,
                              Try a 20% solution of lanolin in turps. I find it effective.
                              Alan
                              #566168
                              Bo’sun
                                @bosun58570
                                Why Lanolin? I recall using it as an apprentice to protect measuring instruments in the metrology department.
                                I guess if it keeps sheep dry, it must have something going for it.
                                #566175
                                Circlip
                                  @circlip
                                  To give it its trade name, Waxoyl.
                                  Regards Ian.
                                  #568035
                                  dieseldaz
                                    @dieseldaz
                                    I also had the same issue although I have insulated my workshop, in the end I fitted an inexpensive greenhouse heater tube on the floor near the workbench and lathe, 120 watt from memory.
                                    Works a treat and keeps the chill off even when in the minus temps, I dont have it on all the time and I can control both the greenhouse heater and the main oil radiator via wifi smartplugs so I dont need to visit workshop to turn off and on plus the benefit of turning the heating on from work before I leave to come home if Im planning to spend a cold evening in the workshop!
                                    Darren.
                                    #568061
                                    Lee Rogers
                                      @leerogers95060
                                      Dehumidifier as above works for me. Time is tight for many of us but I also stick my head round the door and give it all a quick spray over with WD or similar every 3 or 4 days as required, no need to make a mission of the task just do it regularly.
                                      #568065
                                      bricky
                                        @bricky
                                        A Dehumidifier on economy seven, plus in mid winter hesian sacks ,this works well for me .I don't know how much this costs though,I might have to think again with the price rises forecast.I don't heat the workshop so that I don't get fluctuations in temperature which can cause condensation to form,I just dress appropriatley when working.
                                        Frank
                                        #568072
                                        duncan webster 1
                                          @duncanwebster1
                                          Posted by Bo'sun on 09/10/2021 08:59:15:
                                          Esholt (Bradford) sewage works used to extract lanolin from effluent, there was a big wool industry in Bradford. Among others they sold it to cosmetic manufacturers. They also heat treated the solids and sold them to gardeners. Good stuff by all accounts
                                          #568075
                                          Dave Halford
                                            @davehalford22513
                                            It might be caused by chemical means.
                                            That rust causing non acidic flux for soft solder you can get these days.
                                            Brick cleaner have a quiet slow leak out of sight.
                                            Garden products like cheap lawn food usually, green leakage.
                                            Etc etc.
                                            #568076
                                            Samsaranda
                                              @samsaranda
                                              A dehumidifier and oil filled radiator on economy seven and 100 mm of Celotex insulation in the walls and 50 mm Celotex between the roof joists, insulation definitely works. Dave W
                                              #568105
                                              bernard towers
                                                @bernardtowers37738
                                                I would look into your anti corrosion oil it obviously doesn’t do what it says on the tin. Try hydraulic oil.
                                                #568108
                                                not done it yet
                                                  @notdoneityet
                                                  Posted by Samsaranda on 24/10/2021 17:07:45:
                                                  Agreed Dave. While describing what works for us also needs an approximate location. Those in the north of Scotland may need more insulation than we do further south. My ceiling 100mm insulation is shortly going to get another 100mm of rock-wool/glass fibre insulation and a further topping of old ply boards insulated with 25mm EPS.
                                                  Some on here may be in locations that are quite dry and warm, so don’t need the same degree of insulation. My workshop also has the heating/insulation advantage of actually being inside another structure.
                                                  Chris is not so far from you, presumably. Humidity in my workshop is rarely much over 70% and often down around 60% – according to my cheap RH meter.
                                                  #568125
                                                  Chris Suddell
                                                    @chrissuddell31348
                                                    I think I'm done for because my Lathe and Mill are in a concrete garage with no insulation.
                                                    I'm going to clean them up again and apply some rust preventative and I'm going to have to keep on top of them every week. Unfortunately I only use them about every month. Most of my parts are 3d printed.
                                                    It looks like the long term solution is to get them out of the garage and into an insulated wooden shed.
                                                    Thanks for all the replies.
                                                    #568129
                                                    Samsaranda
                                                      @samsaranda
                                                      NDIY, I agree location is an important factor, I am fortunate to live in the South East corner of the country where the climate is vastly different to that of Northern England and Scotland, it’s also the best location for maximum output from P V Solar panels. Eldest daughter lives north of Wigan, we don’t visit her in the winter !!! Dave W
