Does the vinegar etch into the metal or just dissolve the rust?
It turns rust into a kind of goo which scrubs off by hand(I wear marigolds), metal itself is unaffected.
I’ve dunked cast iron and steel parts up to 2 weeks in it, too busy or lazy to take it out.
Buy 10 litres for about a fiver at tesco kinda thing and fill a bucket up with it.
Big long flat bits like my topslides were done in a gardening tray.
Cover parts 100% to keep any oxygen away.
One old calibrated dial came out lovely, while its brother was too worn to be useful, any pitting is also exposed.
A quick scrub with a stiff plastic brush tells you the extent of penetration.
All those old guffy pultra parts in my album got done this way.
Rinse with water, dry thoroughly with paper towels, then I oil it all over to protect it.
It doesn’t seem to evaporate completely either, I’ve had half a bucketful sitting in my garage for 6 months so far.
It IS an acid so I presume even vinegar will literally eat any metal which is left too long in the solution.
The big advantage is you can take your time with it and get a good result.
Just check the progress daily, top up any evaporation on longer jobs with more vinegar.
Saves a LOT of effort where rust is concerned, seems to be very effective, and is safe.
It also eventually eats your marigolds
Edited By ady on 21/07/2011 22:17:48
