Do not use WD-40!
Its protection is very short-lived and its best alternative use to its intended water-dispersant as its name shows, is for flushing old lubricant out of bearings!
It is just a very thin oil diluted with white spirit.
You are best using ordinary lubricating oil or grease, or a protective spray or brush applied oil, like 'Duck Oil', made for such work. Some types slowly dry to a protective film that needs be wiped off with a cloth moistened with white spirit. These protectives are used on the machines imported by firms like Axminster and Warco.
For longer use on static surfaces, petroleum jelly ('Vaseline'
and lanolin are tried and tested materials. An old way to protect wire-ropes is to soak them in a solution of lanolin in meths or white spirit; but note this is not a lubricant. It is a water-proofing that also has the advantage of being safer on the skin than mineral-oils (it was once used for protecting the steel-wire ladders used in caving).
Covers? I am not sure if this is always wise as an impermeable barrier can trap water-vapour under it. I leave my machines uncovered but lightly oily, and they seem fine; in my unheated but moderately well insulated workshop. Unprotected steel seems to rust only a bit less in the house!
Samuel Haywood mentions linseed-oil on garden-tools. Any vegetable oil would be entirely appropriate there, and you could use linseed-oil for other tools, but is likely to dry to a sticky residue.
Year back I encountered castor-oil filling old-fashioned sonar transducers, where it conveyed the signals very efficiently between the active element, through a rubber diaphragm, and the surrounding water. The fluid in our cochleas, and the spermacetti and similar fatty oils in marine mammals' hearing, are the biological equivalents. Castor-oil though, has an affinity for any and every nearby surface, where it sets to a tenacious glue horrible to handle and to clean off!
