Hi John (H) , good to hear you are still up and about. I’m looking forward to hearing about your experiences with casting in due course
I have just highlighted each drawing, right clicked then saved them in My Pictures. Not sure how well they’ll print from there as I’m currently a bit snookered with an inactive printer (Still trying to get your copies done Terry D – hope to have it fixed tonight but failing that it may be a new one so bear with me
Though the text begins by mentioning ‘Radio Control’ I ‘m sure that the reference to
“aerobatics, speed, timer, racing, models of the original and “batutnye” model.”
refer to control line classes. Perhaps ‘batutnye’ is where Google is not equipped with ‘Control Line’
The engine is not, without doubt, an RC motor. The rear exhaust points to a tuned exhaust system – possibly a pipe of conventional layout but then again maybe just a straight length of piped tuned to the rev band. I think that is what this passage refers to…
Recently, in connection with the appearance
of resonant devices the problem of creating high-speed engine rose
especially sharply. No less a challenge than making the engine was its
docking with the cavity and the duct system supply.
After my last post I began to wonder just when I first owned a commercially available rear exhaust motor and thoughts led to a Rossi 15 complete with pipe bought from Michaels Models in the late seventies but then I remembered there was an engine much earlier than that and only just a year or so after this Russian article was published- around ’70/’71. This engine was an OPS 60 water cooled RC motor which I fitted to a power boat but that was, at that time, quite a rare beast. It was extremely powerful with a rev band to match -20 odd thousand as I recall – it certainly used to sing when the pipe came in and the boat would noticeably leap forward in the water. Perhaps small beer by todays standards – the speed model on show at Ally Pally on the BMFA stand – world speed record holder in it’s class I believe – had a specially prepared 2.5cc engine rated at 40,000rpm.
I see from the info on MEN that Derry pointed us to that Super Tigre’s Garafoli patented a boost port system in 1962 so things obviously moved pretty quickly after. I also recall buying a Super Tigre G15 which was a very high performance engine in it’s day but this was side exhaust with a front intake offset to one side. (Bought that one from one of the local traders just outside the gates at Nee Soon Transit Camp in 1966. Any ex squaddies remember Nee Soon?
To make this engine – not a project for the feint hearted I would say would require a cast case to do it to print and as Clive says probably lost wax at that.
It could be machined from solid with some compromises in the inner galleries which should not be too detrimental to performance providing the volumes were adequate and the cylinder porting unchanged but it would have to be made from some esoteric materials and to some pretty high tolerances to get the most out of such an engine. Maybe a toned down 5cc look a like ? I fancy the drum type valve I have to admit. Hmmmm well we’ll have to see
Sorry for going on but this raises some pretty prominent memories – I’d like to thank Cyril for bringing this to our attention for that too
Regards for now – Ramon
Edited By Ramon Wilson on 13/11/2011 16:45:01
