Posted by Circlip on 16/09/2023 09:23:51:
A perfectly good question Andrew and not controversial, just different opinions…
Always useful to explore options. My ER collets are mostly used for tool-holding, but every so often they're good for work-holding as well. In my case, mostly when smallish round jobs are moved repeatedly between machines. I have an ER collet chuck for the lathe, and square and hexagonal Stevenson Collet blocks from ArcEuroTrade:
If I did a lot of collet work, I'd invest in a set of 5C collets. They aren't restricted to round work only, and can grip shorter lengths. (ER collets need an inch or so of round to grip on.) ER and 5C both achieve low run-out. 5C are best for work-holding, but costly. ER are are cheaper because they clamp over a wide range and can be used on both lathe and mill. Which is most useful depends on the type of work being done, and in that sense run-out is secondary.
Edited By SillyOldDuffer on 16/09/2023 11:56:04
