Posted by Andrew Tinsley on 03/09/2023 20:05:36:
… I did use the search function, but didn't come up with a run out figure that was deemed acceptable by the majority of model engineers. …
Apart from the limitations of the search engine, the forum isn't structured as a reference source. Wikipedia is best for that, but you can't have a conversation with it! Wikipedia's article on runout doesn't answer the question either – it's an overview without figures. Maybe we should improve it?
There probably isn't "a run out figure that was deemed acceptable by the majority of model engineers", because the answer depends on the nature of the work. Money matters too! A few things I do are crude enough to let me swap ends in a 3-jaw without worrying about the resulting error. Other work demands much more care, usually with a 4-jaw adjusted to the best of my ability. My lathe, chuck, and my Dial Indicator limit the best I can do to about 0.01mm close to the chuck. Long work requires steadies and an accurately adjusted tailstock. For close up only I have an ER collet chuck, which can be carefully centred with the same Dial Indicator, so similar run out to the 4-jaw. My collets are inexpensive, bought from Warco and ArcEuro, and they're all as good as the chuck.
I rarely attempt high accuracy work, instead working within the ordinary limits of my equipment, which is something like 0.02mm or a thou. I don't use collets often, but once in a while I do a job with round shafts being repeatedly taken on and off the lathe: when this happens collets are much faster than the 4-jaw.
You can guess I don't do much watchmaking or instrument work! If I did, something like a Cowells with a complete set of collets would be needed.
Industry have another reason for wanting low TIR collets, especially ER. They spin them very fast, and a slightly unbalanced collet at 30,000 rpm does a poor job. The same collet at 3000rpm would be fine.
So I come at run-out by asking 'what do I need to do to get the required result?' Quite often there are alternatives; just as well – I dislike spending money on tooling that's better than my lathe or mill can make use of.
However, as Model Engineering is a hobby, others enjoy owning the very best, even if there's no practical need for it. Always nice to have capability and reliable tools, especially if someone else paid for them! Most of us own a mix of more-or-less suitable tools obtained by various methods.
