Howard, condensation in air can even after a while gather in the line to the extent that on starting an engine it may carry over enough to cause a lock, ok for slide valves but not so funny for piston valves. Unless your air is very dry you will still need to lubricate heavily at the end of a session, and turn the engine over every now and again to prevent seizure. The hydrovane pump mentioned by others is near silent and beautifully made but heavy, I have one. I will try my stuart No1 on it and report in due course.
Somehow air doesn't do it for me ! I have run the No 1 on the prestige Hi Dome pressure cooker. 3 weights gives you 15psi and the electric ring gives enough steam for a nice steady speed.
Is this the reason I'm a 49er and still single ?
