Run capacitor value .Bench grinder
Home Forums General Questions Run capacitor value .Bench grinder
  • #477408
    Gerard O’Toole
      @gerardotoole60348
      I need to replace the capacitor in my small hobby bench grinder. it is a CBB61 2.5uF .
      I have ordered from China on EBay but I would like to get one faster. A UK supplier has both 2uF or 4uF available ( but not 2.5uF). I wonder if anyone would know if either the 2uF or 4uF would be safe to use in this application..
      thanks
      Gerard O’Toole
        @gerardotoole60348
        #477432
        AdrianR
          @adrianr18614
          Try rs components, not the cheapest, but they are quick and you know what you get will be OK
          Adrian
          #477435
          peak4
            @peak4
            I've used this ebay company in the past and had quick delivery; You could always contact them and ask for 1st class post, rather than 2nd class, or the £7 option.
            They list a CBB61, the small flat one, as opposed to a CBB60, the larger round one.
            https://www.ebay.co.uk/itm/CBB61-1-1-2-1-5-2-3-4-5-6-8-10-12-uF-AC-450V-Ceiling-Fan-Motor-Running-Capacitor/173277164950?hash=item28581fb596:m:mBW6qq8UV6rrdcID-9GY5Lw
            Bill
            #477437
            Brian Sweeting 2
              @briansweeting2
              Have you tried your local electrical wholesaler, if you have one?
              #477446
              Gerard O’Toole
                @gerardotoole60348
                Thanks for all the suggestions
                Brian, there are no electrical wholesalers open near me ( due to Covid 19 lockdown) and no general hardware stores that are open can help at all..
                Adrian, RS don't list this particular capacitor and I am not competent enough to select an equivalent
                Bill, your link looks good but does not post to my address. However I have found this UK Ebay seller who can post to me but only has the 2 and 4uF sizes. I am just not too sure what the effect of lower or higher values for capacitance on the motor would be. From what I have read , in general, exact values don't appear to be so important. I have ordered the Chinese capacitor but I would prefer get one faster if at all possible.
                thanks for all replying
                gerard
                #477452
                not done it yet
                  @notdoneityet
                  A 2 and a 0.5 micro Farad capacitors in parallel?
                  #477453
                  Brian Wood
                    @brianwood45127
                    Gerald,
                    I don't think you will do any harm to the motor by going for the 4 uF version, the values are not that precise anyway and often have a wide tolerance.
                    Better that direction than going too small.
                    Regards Brian
                    #477456
                    Gerard O’Toole
                      @gerardotoole60348
                      Posted by Brian Wood on 04/06/2020 13:55:31:
                      Gerald,
                      I don't think you will do any harm to the motor by going for the 4 uF version,…
                      Regards Brian
                      Thanks Brian,
                      I will order the 4uF one
                      regards
                      gerard
                      #477501
                      AdrianR
                        @adrianr18614
                        Gerald you can get a 2.5uF CBB61 on ebay **LINK** that says it is a uk supplier
                        FYI any 450V AC 2.5uF Polypropylene film capacitor will do.
                        Adrian
                        Edited By AdrianR on 04/06/2020 17:30:35
                        #477517
                        Gerard O’Toole
                          @gerardotoole60348
                          Thanks Adrian
                          but he doesn't post to Ireland
                          thanks
                          #658353
                          EJ Fuller
                            @ejfuller39032
                            I have an old BG6 bench grinder. I have reason to believe the run capacitor if bad.
                            It is a CBB60. There is no capacitor value listed. Does anyone happen to know the value of the capacitor? The grinder was made in China. I am located in the USA.
                            Thank you in advance for your help.
